Old 05-18-2012, 09:02 AM   #1
Bill Lee/Virginia
Default How To Age A Trunk?
I repaired an old trunk to put on my original 1931 Tudor. I used "black wood furniture stain" to make it all the same color. However, it turned out too shiny (sp?) for the faded paint of the Tudor. Question: What method or substance can I do to remove the shine of the trunk's finish? Thanks.
Bill Lee/Virginia Peninsula
Bill Lee/Virginia is offline   Reply With Quote
Old 05-18-2012, 09:05 AM   #2
charlesea
charlesea's Avatar
Default Re: How To Age A Trunk?
Have you thought about flat black rattle can? or a black primer?
charlesea is offline   Reply With Quote
Old 05-18-2012, 09:14 AM   #3
Tinker
Tinker's Avatar
Dirt?
Old 05-18-2012, 09:26 AM   #4
gweilbaker
gweilbaker's Avatar
What about a dry dust of spray paint, maybe a couple flat dark primers?
gweilbaker is offline   Reply With Quote
Old 05-18-2012, 09:28 AM   #5
the pinstryper
Send a message via MSN to the pinstryper
try four 0 steel wool and a very light touch Its worked for me more than once ; good luck on your project
the pinstryper is offline   Reply With Quote
Old 05-18-2012, 09:54 AM   #6
james hitchcock
james hitchcock's Avatar
I like the light misting of flat black spray paint. The steel wool works. Hobby shops also have a clear coat spray called " Dull Coat " .
james hitchcock is offline   Reply With Quote
Old 05-18-2012, 11:32 AM   #7
FL&WVMIKE
FL&WVMIKE's Avatar
Bill Lee/Virginia .....................
You might try a Scotch-Bright pad. If that doesn't
work, then you could re-paint it.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 05-18-2012, 06:27 PM   #8
broommaker
Dull coat from the hobby shop works fine....
Jim
broommaker is offline   Reply With Quote
