Old 03-23-2012, 04:03 PM   #1
TagMan
Default Front Spring Center Bolt
I received a repro front spring center bolt from a vendor and the square head is only 7/32" height (original is 5/16"), the bolt diameter is .024" smaller than O.E. and the nut is only thick enough (.165") for about 3 threads of engagement.
Does anyone make a center bolt in the correct dimensions?
TagMan is offline   Reply With Quote
