Old 03-21-2012, 08:28 AM   #1
cobra2
Default Hand crank wiper
On a '28 roadster pickup, does the hand crank wiper just go through a hole in the windshield frame with no bushings or brackets?
Thanks again
cobra2 is offline   Reply With Quote
Old 03-21-2012, 08:34 AM   #2
wrndln
Default Re: Hand crank wiper
The 28 and 29 windshield frames had a small tube, maybe 1 1/4" long or so that the hand wiper went through. I don't think there was any bushings or anything else that were used. I could be wrong of course. Windshield on Model A's with hand wipers used the small tube, model A's with vacuum and electric wipers just had a series of holes in the top of the windshield frame.
My mistake, I misread your post as a CCPU wiper question. Never mind.
Rusty Nelson
Old 03-21-2012, 10:51 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I'm thinking the pickups had a steel tube for the wiper, but my 28 Phaeton just runs through two holes in the windshield frame and with no bushings.
Old 03-21-2012, 10:59 AM   #4
d.j. moordigian
d.j. moordigian's Avatar
Open cars had no bushing...the W/S frame was the bearing surface.
On CCPU, there is a rolled sheet metal piece that is spotwelded to the W/S
frame for a bearing surface.
The open wiper is different than the closed cab.
Dudley
d.j. moordigian is offline   Reply With Quote
Old 03-21-2012, 11:08 AM   #5
Charles Reese
Charles Reese's Avatar
* believe Mr. Moordigian to be correct re: no tube on Open PU.
** comparison pix courtesy Mr. Neil Wilson (short shaft = open PU; long shaft - CCPU)
*** other pix of my '28 Open PU during 'fitting' stage.
Charles Reese is offline   Reply With Quote
Old 03-21-2012, 11:18 PM   #6
cobra2
Wow, thanks guys, you make it so easy.
Old 03-22-2012, 10:16 AM   #7
d.j. moordigian
Charles,
I always thought there should be some kind of washer on the front side of
the wiper arm(as it goes through the W/S frame) in your second photo. But have
never seen anything in that area.
Do you think that is correct? Marco?
Dudley
Old 03-22-2012, 11:10 AM   #8
Charles Reese
there is a small 'upset' near the curve of the shaft that i believe is intended to keep the washer in place. this is the configuration i found on the vehicle (not to say someone had not modified somewhere in the past)
Old 03-23-2012, 07:02 AM   #9
cobra2
Drilling a hole on the curve of the winshield frame might be a challenge. I thought my frame was original bit it doesn't have that hole.
Turned out to be a five minute job and looks and works great.
