Old 02-05-2012, 02:38 AM   #1
squiresurf
Default 32 rear brakes on Model A
Ok guys i know a few of you have done this mod & despite asking in a pm im not having any luck in help ?
Can someone let me know how i attach an emergency brake to this mod ?
Any help would be so appreciated ?
Thanks .
John
squiresurf is offline   Reply With Quote
Old 02-05-2012, 08:34 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 32 rear brakes on Model A
John, if you don't mind me asking, what is the attraction of this modification? If my math is correct, you would be picking up about 4% to maybe 4½% more braking surface area, ...which doesn't seem like it would be worth the effort. Am I missing something?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-05-2012, 12:29 PM   #3
just plain bill
just plain bill's Avatar
Thanks .
John
I welded an arm to the brake cross shaft and intend to use a piece of chain or possible a cable to connect the original emergency brake lever.
just plain bill is offline   Reply With Quote
Old 02-05-2012, 01:53 PM   #4
squiresurf
Brent , i think you are possibly quite right given the mods required to do this .
I have 32 front brakes & they are a damn sight better than my old model A ones & thought i would like 32 all round .. Quickly coming round to your way of thinking though ! Thanks for confirming my doubts !
Thanks guys !
Old 02-05-2012, 02:25 PM   #5
Jim Brierley
1935's are even better as they are wider than 32's. I did like Just Plain Bill did, now all 4 wheels are part of the parking system, the only problem is with the e-brake on the stop lights are on too, so a cut-off switch is necessary.
Jim Brierley is offline   Reply With Quote
Old 02-05-2012, 05:11 PM   #6
columbiA
Jim B, Couldnt you use the park brake rod with the long slot in it from a early 28 AR,then you wouldnt need the cut-off switch?
columbiA is offline   Reply With Quote
Old 02-06-2012, 11:39 AM   #7
Jim Brierley
Probably, but I didn't have one of those.
