Old 01-07-2012, 11:09 PM   #1
spdway1
spdway1's Avatar
Default Windshield Glare from back window
What do you do about the windshield glare from back window?
I am thinking about putting dark window tint on the back window of my daily driver "A".
spdway1 is offline   Reply With Quote
Old 01-07-2012, 11:22 PM   #2
Tony S,Fl.
Tony S,Fl.'s Avatar
Default Re: Windshield Glare from back window
Pull the curtain on the rear window down . Thats why it was put there. Tony
Tony S,Fl. is offline   Reply With Quote
Old 01-07-2012, 11:24 PM   #3
WTSHNN
WTSHNN's Avatar
Not all A's had a rear curtain...
I've seen people use a retractable mesh type shade that allows you to see through but helps reduce the glare.
-Tim
WTSHNN is offline   Reply With Quote
Old 01-07-2012, 11:29 PM   #4
spdway1
spdway1's Avatar
Sorry Tony, I did not mention it is a 29 Closed Cab Pick Up!
Old 01-08-2012, 12:35 AM   #5
Jim/GA
Jim/GA's Avatar
If your vehicle did not come with a back window shade, maybe a stick-on mesh shade like this would help with the glare:
http://www.amazon.com/Rear-Side-Wind...ref=pd_cp_ba_3
The one they sell for the rear window is too big, but maybe the one they sell for side windows would be good for an A.
Jim Cannon
Former MAFCA Technical Director
"Spread the Joy! Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 01-08-2012, 01:14 AM   #6
Craig Lewis
Craig Lewis's Avatar
Tinting the back glass will make it 2 or 3 times Worse.
It seems at night, under any perceptible light, your front & rear windows become mirrors lookin at each other. With a rearview mirror and your head amidst this box of mirrors...all mirrin' each-other...you can feel like a deer in the headlights.
Add the reflective qualities of tint film and you have a visual skating rink!
I tinted the backglass of an import truck years ago & with the dashlights and stereo reflection thrown in it was crazy. The medium dark tint also reduced normal visibility out the back to nearly zero after dusk and made lane changing a 2 person job.
I wonder if a handy person could build a day/night mirror into the Model A bracket by cutting up a modern car "dimming" mirror and using the parts?
These operate on the principal of a wedge shaped mirror in behind a glass. The wedge is silvered on the backside and tilts when you flip the mirror up, the mirrored surface is pointed toward the ceiling and the front glass is vertical, dimly reflecting cars behind.
Craig Lewis is offline   Reply With Quote
Old 01-08-2012, 09:21 AM   #7
V4F
V4F's Avatar
install a curtain . ez fix ............ steve
V4f
V4F is offline   Reply With Quote
Old 01-08-2012, 09:52 AM   #8
'29wagon
keep it clear, how 'bout poly/spray, mat finish on the interior , just the rear ?
'29wagon is offline   Reply With Quote
Old 01-08-2012, 11:46 AM   #9
1931 flamingo
1931 flamingo's Avatar
Open the front window a skosh.
Paul in CT
Old 01-08-2012, 06:42 PM   #10
Ice man
Ice man's Avatar
I run with my windshield open a bit all year long, but here you can get away with it. Iceman
Ice man is offline   Reply With Quote
Old 01-09-2012, 01:26 AM   #11
Popeye31
Popeye31's Avatar
I never notist it in my 29 ccpu but thanks to you I will for now on. LOL
Live your dreams
Popeye31 is offline   Reply With Quote
Old 01-09-2012, 05:38 AM   #12
Clem Clement
Clem Clement's Avatar
I also run with my front window at the knotch.
Clem Clement is offline   Reply With Quote
Old 01-09-2012, 11:21 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Two magnets and a piece of cloth would make a quick fix curtain. Maybe some of that see through curtain material would stop the glare but allow you to see behind.
Old 01-09-2012, 04:39 PM   #14
Special Coupe Frank
Special Coupe Frank's Avatar
I have the same problem with my '28 Coupe at night.
I picked-up a cheapy pair of perforated roll-up shades from Wal-Mart that attached with suction cups or hooks ( I snapped them into the top of the garnish moulding ).
Doesn't look period, but it does cut-down on some of the glare.
Someday I will put a proper cloth shade in.
Opening the windshield a bit also helps.
Good luck,
SC Frank
Special Coupe Frank is offline   Reply With Quote
