Old 10-15-2011, 03:14 PM   #1
b ramsey
Default laycock volvo overdrive oil
ok ive searched, 30 wt oil for the unit. BUT!! how much? dont tell me to the bottom of the fill plug. it is drilled and tapped on the very top of the unit. type j. thanks.
b ramsey is offline   Reply With Quote
Old 10-15-2011, 07:31 PM   #2
glenn in camino
glenn in camino's Avatar
Default Re: laycock volvo overdrive oil
I use 50 weight racing oil in mine. Works fine.
glenn in camino is offline   Reply With Quote
Old 10-15-2011, 07:33 PM   #3
glenn in camino
When filling it, I fill until it runs over.
Old 10-15-2011, 08:34 PM   #4
b ramsey
when i pulled it from the wrecking yard, it was filled with ATF. so volvo specifies type F. also, i see the is a small bolt (plug) on the side. ill fill it till it runs out of there. fill it from the larger plug someone put on the top. any reason i shouldnt use the ATF?
Old 10-15-2011, 10:11 PM   #5
wensum
wensum's Avatar
I have the "J" type in My Lancia Lambda (out of a Volvo)
In many cars with this overdrive installed, it shared the gearbox oil.
So this should indicate what type of oil they were originally intended to work with.
Also, if the overdrive is remote from the gearbox as in Most Model A installations, there should be some thought given to fitting a reservoir as the amount of oil contained solely by the overdrive is limited.
The gentleman who recently overhauled the overdrive suggested a 80-90 grade oil with a non slip additive?
wensum is offline   Reply With Quote
Old 10-16-2011, 12:01 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Yes, up to the small plug, yes ATF.
21 years working on those Fargestrarders!
"THE ASSISTANT GURU OF STUFF"
Old 10-16-2011, 12:08 AM   #7
Geo. H
I got my Laycock OD about ten years ago. The builder told me to put a quart of 30 wt oil in it. It's worked for me all these years.
Geo. H is offline   Reply With Quote
Old 10-16-2011, 12:13 AM   #8
aaron griffey
Send a message via Yahoo to aaron griffey
The Volvos used 80-90 except when they had an overdrive.
In the overdrive equipped cars the transmission bearings were different and the trans and overdrive used ATF.
Since there is a clutch in the overdrive that engages when the unit is under power it would be bst to use ATF as it will not cause the clutch to slip for a while like it may do with motor oil or heavy gear oil although with the limited power the model A engines out out it obciously doesn't hurt too much to use whatever kind of oil you want.
I'd still use ATF.
aaron griffey is offline   Reply With Quote
Old 10-16-2011, 12:18 AM   #9
b ramsey
thanks guys!
Old 10-16-2011, 06:47 PM   #10
Herb Concord Ca
I've had mine for 8 plus years, now on it's second Model A. Started with AFT and later the builder recommend 30wt motor oil. If your pump begins to wear, and doesn't shift into second over very well, then try 50wt.
I live in CA where we have hot summers. So 30 wt might be you best choice.
The overdrive will hold 1 quart of oil.
Herb Concord Ca is offline   Reply With Quote
Old 10-16-2011, 07:38 PM   #11
BILL WILLIAMSON
Model J is a good strong overdrive. Somewhere, I read that someone was making a deeper sump for more oil capacity.
Maybe Rich & Mitch in Bakersfield, Ca.
