Old 09-24-2011, 07:09 PM   #1
Bill in NJ
Default Drive shaft and tork tube
I have several drive shafts and outer tubes that I saved years ago as rebuilders wanted them to make the over drive version for the Model As. Do places still want these?? Scrap prices are up, social security checks are down. would rather save them if people could use them.
Bill in NJ is offline   Reply With Quote
Old 09-24-2011, 08:19 PM   #2
dumb person
dumb person's Avatar
Default Re: Drive shaft and tork tube
People can use them you just have to find those people. And if they say no beat them with the drive shafts until they say yes
dumb person is offline   Reply With Quote
Old 09-24-2011, 08:27 PM   #3
V4F
V4F's Avatar
i would contact a manufacture of od's . like mitchell in colusa ca. ............ steve
V4f
V4F is offline   Reply With Quote
Old 09-24-2011, 08:36 PM   #4
KCTA Chris
KCTA Chris's Avatar
Sell the tubes on the HAMB. Torque tubes are popular material for exhaust headers. I used them on a few of my builds and seems like a "Damn, I tossed those but now have to have it" part. Also discarded rear wishbone ends for shock mnts brings a buck or two.
C.
KCTA Chris is offline   Reply With Quote
Old 09-24-2011, 08:45 PM   #5
Kevin in NJ
How are the drive shafts?
I have a pile of scrap or less desirable shafts.
You need to look at the taper end. Is it nice, not scored, how is the key way and threads?
Then look at the other end. How are the splines, bearing area and seal area.
I have a couple the spline ends are loose, one with pitting on the bearing and 2 more with marginal tapers. The one that was good at both ends is in my car.
Clearly good ones need to be saved cause you never know when you will need one. Odds are that more than one is marginal or bad.
Kevin in NJ is offline   Reply With Quote
Old 09-24-2011, 11:29 PM   #6
b ramsey
i could use a driveshaft that hat has the bearing/seal surface in good shape. dont care about the rear part, because im gonna whack that off.
b ramsey is offline   Reply With Quote
Old 03-11-2012, 10:28 AM   #7
Bill in NJ
T tt
Old 03-11-2012, 10:49 AM   #8
400A-64
400A-64's Avatar
Mitchell Makes their Own drive shafts. (two piece) the length depends on the car.
When you purchase a Mitchell , Every thing is NEW except your pinion gear!
Bruce Davis [email protected]
400A-64 is offline   Reply With Quote
Old 03-12-2012, 02:39 AM   #9
CarlG
CarlG's Avatar
The guys that make the F150 4-speed overdrive conversions consume a drive shaft, torque tube, and a pair of rear radius rods for each kit they build.
Old 03-12-2012, 07:20 AM   #10
62pan
I need one with the bearing, splines and seal surface in good shape. Too many are bad in this area. I am not interested in the taper end as that will be cut off for a quickchage. PM me if you have one.
62pan is offline   Reply With Quote
