Old 06-27-2011, 09:13 PM   #1
allen
allen's Avatar
Send a message via ICQ to allen
Default cowl light template
Hi does anyone have a template or know the measurement for installing cowl lights on a 30 Tudor
allen is offline   Reply With Quote
Old 06-27-2011, 09:29 PM   #2
ford1
Default Re: cowl light template
there is a hole in the body support under the fuel tank inside the car on both sides of the body cowl, its there to locate the position of the cowl lite, make a wooden dowl about an inch long the same size of that hole, drill a 1/4" hole in the center of the your dowl, put it in the hole under tank and use it to locate the center where you want to drill a small hole, use a center punch thru the dowl to mark the spot where to drill, drill from inside out, then use a larger hole from the out side to prevent chipping the paint you will have to put a spacer between the brace and body cowl to take up the space, if you dont you will bend the body cowl
ford1 is offline   Reply With Quote
Old 06-27-2011, 09:56 PM   #3
allen
allen's Avatar
thanks as always al
