#1 |
I suppose I could look this-up in a reference book, but I happen to be on-line now. What is the correct paint color for the starter motor? Engine green or black? Thanks!
#2 |
Black
#3 |
And it looks better if it isn't thick and super shiney, like some I've seen. A couple of thin coats from a spray can of gloss black will look good.
#4 |
The new Restoration Guidlines states, "All starters were painted black. The color varied from satin to semi-gloss".
#5 |
Lack is nice
WANTED MODEL T TOURING CAR UP TO 1925 WANTED 28 OR 29 FORD MODEL A TUDOR OR FORDOR 1972 OLDSMOBILE 442 CONVERTIBLE 1969 CHEVELLE/MALIBU- SOLD 2003 MONTE CARLO SS PACE CAR EDITION # 841 OF 1401- SOLD |
#6 |
#7 |
I paint mine semi gloss-satin black.
#8 |
I've been using Rustoleum satin black thinned with Acetone to spray, can leave in gun for small parts...it has the correct patina for most frame and running gear parts, plus generator and starter...
The only thing worth learning is what you learn after you know it all !!
#9 |
Be sure not to paint the surface that contacts the flywheel housing as it is part of the ground path. And yes, it is black.
Charlie Stephens |
