Old 12-14-2025, 10:29 PM   #1
Lawrie
Lawrie's Avatar
Default 34 wiper arm
Having just fixed up the vacum wiper motor on my 34, i,m trying to fit the wiper arm to the shaft and can't work it out. man, its one fiddly little contraption.
is anyone is familiar with how you attach it to the wiper shaft.
Thanks Lawrie
Lawrie is offline   Reply With Quote
Old 12-14-2025, 11:59 PM   #2
Brian
Brian's Avatar
Default Re: 34 wiper arm
Place the small end of that teardrop shaped piece over the arm of the wiper at bottom of the spring. place the hook at top of arm through the hole in wiper motor shaft.
push up the teardrop, compressing the spring and hook the top of it over the shaft, that little crescent dodad in top of the teardrop, locates in the groove of the wiper shaft.
really, they are a crap design!!!
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 12-15-2025, 12:54 AM   #3
petehoovie
petehoovie's Avatar
Thanks Lawrie
Old 12-15-2025, 01:46 AM   #4
Lawrie
Lawrie's Avatar
Thanks Brian
got it sorted ,you are right a crap design
But got the 34 vac wiper working a treat, so I think I will replace the little electric one on the 33 and put in the NOS vac one .
how did you go getting the studs out of the engine the other month.
Lawrie
Old 12-16-2025, 01:43 PM   #5
Newc
Newc's Avatar
FYI; My correct stock type wipers on my '34 sdn left the car at 55 mph !!! Newc
Old 12-16-2025, 04:48 PM   #6
Brian
Brian's Avatar
Yeah, I gave up on them years ago for that very reason!
Old 12-17-2025, 12:29 AM   #7
Lawrie
Lawrie's Avatar
Yes , my wiper arm will reside in the glove box,
Rainex on the glass is the go, I just got sidetracked and got the vac wiper motor working a treat.
Lawrie
Old 12-17-2025, 02:50 PM   #8
johndee138
johndee138's Avatar
The whole assembly WILL fly off at speed!
I keep my wiper blade in the glove box and a small piece of rubber hose or similar over the end of the arm. No danger of scratching the paint if the motor is engaged. Rain-X of course, but sometimes it is a necessary item to have at the ready.
johndee138 is offline   Reply With Quote
Old 12-17-2025, 03:05 PM   #9
The Art Doctor
The Art Doctor's Avatar
Now I'm going to go out to the garage and take mine off and put it in the glove box for safe keeping, thanks for the advanced notice!
Is it just the blade that will go flying off or the whole arm? The arm is on there pretty good with all that spring tension and was a bit of a struggle to remove.
The Art Doctor is offline   Reply With Quote
Old 12-17-2025, 05:54 PM   #10
johndee138
johndee138's Avatar
The first time it happened to me, the whole shebang was gone. Just the stud that goes through the roof was left
I think the wiper blade becomes a sail and it is barely attached on a good day anyway.
