Old 04-26-2011, 09:22 AM   #1
saints
saints's Avatar
Default Man is it hard to find a flathead guy in Ok.
Ok so I have since picking up my first flathead been looking for a machine shop that will work with me on building a flathead without results...... I have a job which I am out and about all day and I take my down time to visit with local machine shops to see if they can help me in my flathead block.... well most I get the No we can’t help you because of the special tooling needed to do "THOSE" engines????And I did find a guy that is a good engine builder but has never worked on a flathead willing to do it..... So what do I do? Do I let the guy TRY out flathead building with my help blind leading the blind so to speak but he has allot of experience in building engines.......I have been collecting flathead tools so that I have everything I need to do the job myself except machining and that seems to be the hold up
Thanks to russ/40 for helping me out on the valves and out of 3 complete engines I think I have one that I can get running by myself with just a hone and new rings and valve lapping
But if all doesn’t go well on this engine Im screwed in the machine shop part of the build…
FLATHEAD ADDICT
saints is offline   Reply With Quote
Old 04-26-2011, 09:51 AM   #2
TJ
TJ's Avatar
Default Re: Man is it hard to find a flathead guy in Ok.
If you are a V-8 Club member why not check with the members listed in the roster in your area. I'm sure someone will have a recommendation. If you are not a club member it's a good reason to join. The V-8 Times magazine and roster is worth the price of admission.
Old 04-26-2011, 10:16 AM   #3
Cavanal40
Give Howard Tribbey a call at 918-865-7455 and check out his web site at www.howardscustomflatheads.com. He uses a shop in Tulsa to clean up and mag the block plus any machining and he does the assembly. He also has complete engines for sale.
Cavanal40 is offline   Reply With Quote
Old 04-26-2011, 10:16 AM   #4
okiedokie
okiedokie's Avatar
Did you ever look for the guy in Grove that specializes in flatheads? I don't remember the name, but I am sure if you call the NAPA store there they can tell you.
okiedokie is offline   Reply With Quote
Old 04-26-2011, 10:33 AM   #5
Ross F-1
Ross F-1's Avatar
There is a shop in Wichita that always has reman engines on eBay, it's not that far from you by western standards.
Ross F-1 is offline   Reply With Quote
Old 04-26-2011, 10:45 AM   #6
flatheadernie
I can give you the name of a guy in Moore OK . ernie n Tx
flatheadernie is offline   Reply With Quote
Old 04-26-2011, 10:55 AM   #7
saints
saints's Avatar
well!!! like always I guess I was asking and looking in the wrong places
I talked to howard via e-mail and hes a nice guy buy twice the price of the quotes I got out of state....I did check with the guys in kansas and they would but by the time I drove up there and had them check the blocks Im out the price to have them machine it.....Ill give some of the suggestions a try
FLATHEAD ADDICT
Old 04-26-2011, 10:56 AM   #8
saints
saints's Avatar
Ill do that thanks
FLATHEAD ADDICT
Old 04-26-2011, 11:15 AM   #9
Mike in AZ
Mike in AZ's Avatar
here's a link to Joe's Speed Shop in Ponca City??....he might be able to help you....good luck....Mike
http://www.joesspeedshop.com/joesproducts.htm
Mike in AZ is offline   Reply With Quote
Old 04-26-2011, 11:45 AM   #10
Fordestes
Give me a call If I cant help you, I can direct you to someone here in Okla.
as we all know a lot of the older machine shops are fading away, however
I still send out a little flathead machine work, also you might check around for some industrial engine shop as a lot of the older industrial engines and compressors were somewhat heavier and also were flatheads of many difrent brands.
Fordestes,
405-623-8419
Fordestes is offline   Reply With Quote
Old 04-26-2011, 12:36 PM   #11
flatheadA
Didn't we just go through this in Texas
flatheadA is offline   Reply With Quote
Old 04-26-2011, 01:30 PM   #12
butchbov
butchbov's Avatar
Give Ray & Chris in Midwest City a call at 800-732-6029 or email [email protected].
http://www.shoeboxford.com/.
Butch
In a world filled with stress it is better to give than to receive.
butchbov is offline   Reply With Quote
Old 04-26-2011, 02:00 PM   #13
Coupe35
I don't get it. Unless your having new babbit bearings pur in, any machine shop can bored or grind valves.
Coupe35 is offline   Reply With Quote
Old 04-26-2011, 02:48 PM   #14
saints
saints's Avatar
I thought the same thing and I have heard every excuse in the book of why they "cant" do the job
FLATHEAD ADDICT
Old 04-26-2011, 02:49 PM   #15
saints
saints's Avatar
Thanks I will... I guess I wasnt asking the right people for Help
FLATHEAD ADDICT
Old 04-26-2011, 02:53 PM   #16
oldford2
oldford2's Avatar
Like any project, take one step at a time. First you need to get the block hot tanked and cleaned. Then magnafluxed and pressure tested to be reasonably sure you have a good block. Then you can take your measurements and plan the next steps. John
oldford2 is offline   Reply With Quote
Old 04-26-2011, 02:57 PM   #17
Dave72dt
You're probably right on the boring. Valves are a different matter altogether. All valve grinders/cutters I know of center off the guide and with the valve out, the factory guide isn't stable enough for accurate seat work. A special pilot is used for seat work and most machine shops don't and won't have it for the few times they might ever have a need for it.
Dave72dt is offline   Reply With Quote
Old 04-26-2011, 03:03 PM   #18
toby
toby's Avatar
Ray Marler in Midwest City, OK. www.shoeboxford.com. He has built many flatmotors.
800-732-6029
toby is offline   Reply With Quote
Old 04-26-2011, 03:59 PM   #19
saints
saints's Avatar
we all are not born knowing who works on flatheads so I asked
FLATHEAD ADDICT
Old 04-26-2011, 04:11 PM   #20
Planojc
Planojc's Avatar
The best way to find resources for anything pertaining to the Flathead Ford hobby is to either join a local Early Ford V8 club or contact one of the members. Most of them have been their and done that.
Planojc is offline   Reply With Quote
