Old 11-25-2025, 11:59 AM   #1
32Bee
Default 35 Directional Signal Lights
While I wait for Small's Auto Wire (company who bought Rhode Island Wiring)
to open up, I'm trying to get additional info as what needs to be done in
order to install directionals on my 35 convertible sedan. I've bought a nice set
of fog lights with brackets for the front of my car and I've been told I should be
able to use my stock tail lights for the rear. So my question is, what ends up
happening in order to be able to use the stock rear lights and will it be the
parking bulb that will be used for this purpose? Also it would be nice not to have the switch for the directions located on the column as I've also been told
there is a device (switch) that can be mounted on the under side of the instrument panel. What are there for comments about doing that?
32Bee is offline   Reply With Quote
Old 11-25-2025, 12:12 PM   #2
glennpm
glennpm's Avatar
Default Re: 35 Directional Signal Lights
Take a look at the unit offered below. I have it in my'32 and very pleased with it.
www.turnswitch.com
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 11-25-2025, 01:40 PM   #3
The Art Doctor
The Art Doctor's Avatar
I like the look of the early VW beetle switch. No ugly hose clamp wrapped around the column like so many of the add on ones have.
The Art Doctor is offline   Reply With Quote
Old 11-25-2025, 01:55 PM   #4
KiWinUS
KiWinUS's Avatar
I use fog lights for front also with relays as they pull a good few amps. The rear tie into the brake light system it’s the easy part.
Old 11-25-2025, 02:38 PM   #5
Zeke3
Zeke3's Avatar
You must run an additional wire for the brake lights so that the right side can be separated from the left side. Originally your car only has a single wire supplying both brake lights with a crossover harness at the rear of the car.
Zeke3 is offline   Reply With Quote
Old 11-25-2025, 05:43 PM   #6
corvette8n
corvette8n's Avatar
The previous owner of my car installed dual filament sockets in the rear light assembly and also in the fender mounted lights, and wired it appropriately on my ‘41.
Old 11-26-2025, 07:48 PM   #7
TJ
TJ's Avatar
The Volkswagen switch is an excellent idea. It looks like it could have been a Ford accessory. I used one on a '36 and a '32. You can get a wire diagram on-line if the switch does not come with one.
Old 11-26-2025, 10:44 PM   #8
petehoovie
petehoovie's Avatar
