Old 09-30-2025, 10:42 AM   #1
Planojc
Planojc's Avatar
Default Two dead cylinders on a 59ab
New coil, Distributor and Carb from Charlie NY, new plugs and plug wires on a 59AB. All cylinders have good compression at about 110. Number one and two cylinders show no change when plugs are shorted to ground. Both are getting hot spark to the plugs and through the plugs to the electrode. It acts like no fuel is making its way to the intake valves on those two cylinders. The valves on both cylinders are clean and are opening and closing like they should as seen with a borescope camera. Short of removing the intake, does anyone have any suggestions? I'm running out of options
Planojc is offline   Reply With Quote
