Old 08-26-2025, 11:36 PM   #1
35sedanconvert
Default Stromberg inlet valve wrong size
I have what I believe to be a Stromberg 48. Marked 1 1/32. Trying to rebuild it and the inlet valve from stromberg is too small for the hole in the carb. Only see one inlet valve on Stromberg's site. What am I missing? TIA.
35sedanconvert is offline   Reply With Quote
Old 08-26-2025, 11:41 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Stromberg inlet valve wrong size
Old 08-26-2025, 11:44 PM   #3
Brian
Brian's Avatar
At some stage I'd guess that the thread was stripped in the body of the carb, was tapped oversize and a special oversized threaded fitting was used
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 08-26-2025, 11:49 PM   #4
petehoovie
petehoovie's Avatar
The one on the bottom in the first picture and on the right in the second picture appears to be an after-market Grose-Jet style needle & seat float assembly....
Old 08-27-2025, 12:07 AM   #5
35sedanconvert
It is. Straight from Stromberg. My problem isn't the style, it is that the threads are different size. I would like to replace mine and can't seem to find one that is the larger size thread.
Old 08-27-2025, 12:12 AM   #6
petehoovie
petehoovie's Avatar
Try Speedway Motors > https://www.speedwaymotors.com/Grose...tor,42294.html
or > https://stromberg-97.com/parts/s-jet-inlet-valve/
Stromberg may have screwed up and sent you the wrong size valve...Call them and talk to a real person...
Old 08-27-2025, 06:26 AM   #7
Terry,OH
Terry,OH's Avatar
The larger inlet is a repair to the threads which have been increased in size. So the new inlet does not fit because it is of standard size. The original size is 7/16" and the oversize is 1/2" You can contact Max Musgrove, the repair technician at Stromberg for a reducer so you can use the standard size or look for another top casting. If you go with the reducer locktight it in place so it does not leak or come out.
Old 08-27-2025, 08:38 AM   #8
35sedanconvert
Thanks to all for the answers.
Old 08-27-2025, 10:17 AM   #9
Kube
Super Moderator
Kube's Avatar
Pete, you are correct. I have found them in carburetors that tend to starve for fuel. In my opinion, they are junk.
Old 08-28-2025, 05:51 AM   #10
nickthebandit
Back in the day there were several different oversized fuel inlet fittings to repair the original fuel inlet that was usually caused by too heavy a hand when tightening the original fuel fitting. I have had several different over-sized fittings in the past.
nickthebandit is offline   Reply With Quote
Old 08-28-2025, 06:46 PM   #11
aussie merc
aussie merc's Avatar
talk to uncle max get it back to standard saves headaches down the track
aussie merc is offline   Reply With Quote
Old 08-28-2025, 08:42 PM   #12
Andy
I have made inserts. I had bought a couple at a swap and found the damage at home. I used a 9/16 fine bolt and tapped it to the inlet thread. I partially tapped the lid to the 9/16 threads so the insert could not screw thru. The gasket still seated on the lid. They for sure never stripped out again.
Andy is offline   Reply With Quote
Old 08-29-2025, 08:27 AM   #13
john in illinois
john in illinois's Avatar
All curant Stromberg valves are Gross jet style. I had a problem of them sticking closed after sitting for the winter. The last few years that has not happened and they work well. I looked for standard type valves at Daytona
carburetor, but was told they do not make them for 97's.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 08-29-2025, 11:11 AM   #14
barnfind08
I have nos valves dm for prices and quantity needed
barnfind08 is offline   Reply With Quote
Old 08-31-2025, 11:44 AM   #15
uncle buck
uncle buck's Avatar
Of course you do Fred! Sometimes we overlook and forget about your amazing inventory of NOS and NORS parts. We are blessed to have you here on this site.
uncle buck is offline   Reply With Quote
Old 09-06-2025, 07:59 PM   #16
scicala
scicala's Avatar
I'm not a fan of the Grose Jet too. I did a six carb set up on an '57 Olds J2 engine, and two of the six carbs had flooding issues. The fuel pressure was not excessive.
Too bad all of the official Stromber carb kits come with them.
Sal
