#1 |
finding lots of missing/incorrect/incomplete fasteners on our new '29.
looking for an illustration and/or description of nuts and washers used on the rods at both ends. is it in the Judging Standards somewhere?
our next Model A has arrived.... ![]() |
#2 |
Also see https://www.snydersantiqueauto.com/p...4017&cat=41737 and https://www.snydersantiqueauto.com/p...9152&cat=41737
#3 | |
![]() Quote:
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#4 |
Not in standards.front, rear
www.whidbeymodelaclub.com |
#5 |
#6 |
Bob Bidonde Last edited by Bob Bidonde; Today at 07:48 AM. |
#7 |
13mm?? That’s ½”…
#8 |
I purchased a large amount of original hardware (bolts, washers, nuts, screws) a few years ago. It is all sorted by part number. If you have the part numbers, I might have what you need. [email protected]
#9 |
The '28s were a tube with a visible seam. The '29s were a solid rod. I don't know when the change over was.
#10 | |
![]() Quote:
The 1928-29 used larger diameter rods than 1930-31. |
#11 |
#12 |
Restoration Guidelines, Engine Compartment page 1-16: "The radiator support rods were 3/8" diameter seamed tubular type from the beginning of production through mid 1929 when they were changed to 9/32" solid steel for the remainder of production."
Per the finishes chart, the rods were painted black and the washers and nuts were raven finish. "Through mid 1929" would mean through August. |
