Old 08-04-2025, 05:18 PM   #1
Ken B
Ken B's Avatar
Default 1930 Town Sedan Seat Removal
I have a 1930 Town Sedan. I need to remove the front seat frame to get some repairs done on the upholstery. I can't find out how it is fastened to the floor. Any suggestions? Thanks, Ken
Ken B is offline   Reply With Quote
Old 08-04-2025, 07:04 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: 1930 Town Sedan Seat Removal
Have you removed the bottom cushion? You should be able to see all the hardware with the cushion out.
I think there is 4 bolts on each side to attach it to the seat rails. Been a long time... way back I moved my seat 3" rearward to give my long legs more room.
Old 08-04-2025, 07:40 PM   #3
Marshall V. Daut
1929 Murray Town Sedan front seat carriage, but it should be the same for a Briggs Town Sedan/Fordor.
Marshall
Old 08-04-2025, 10:46 PM   #4
Cape Codder
Cape Codder's Avatar
Ken B - Just TODAY I removed exactly what you are wanting to do and had the back rest JUST in front of the REAR Cushion. As Y-Block wrote "THERE ARE FOUR BOLTS" holding the wood to the rails AFTER REMOVING SEAT CUSHION !
Doing that will give you access to taking, I believe it is called THE BUCKET, BUT not positive, which has the back rest in it !
OH! my car TESSIE, pictured in the Avatar, is a 1930 Fordor DeLuxe BLINDBACK for the record!
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 08-05-2025, 09:16 PM   #5
Ken B
Ken B's Avatar
Yes, I removed the seat cushion. I don't see the four bolts in the pictures. I will try to take some pictures of my own and post them soon. Thanks!!!!
Old 08-06-2025, 06:42 PM   #6
Ken B
Ken B's Avatar
I think I figured out how to remove the front seat frame. I see the bolts on either side but the back one isn't accessible. I adjusted the seat frame until it hit stops on either side. I would think if I remove the stops, that the seat frame would adjust all the way off. Would that be correct?
