Old 07-31-2025, 01:32 PM   #1
tpepin
Default 31 Victoria hinge removal from door
Hi All looking for advice on removing hinges from door side. Took passenger one off but not only had to drill the rivets but also had to chisel off the weld behind it. Is this normal or am I missing something?
Thanks
tpepin is offline   Reply With Quote
Old 07-31-2025, 04:39 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: 31 Victoria hinge removal from door
Your are speaking of the door itself…..not the cowl pillar?
If door, yes, what you describe is normal. I do everything possible to not have to remove the door hinge attached to door. Has to be last resort.
Oldbluoval is offline   Reply With Quote
Old 07-31-2025, 05:36 PM   #3
tpepin
Thanks that’s what I thought. I can’t believe they welded it from the back. Oh well I’m going to cut the door side off the bottom driver side. I drilled the pin out slightly off center and it won’t come out. What a pita.
