Old 07-06-2025, 02:39 PM   #1
Rocky Rocket
Rocky Rocket's Avatar
Default Water inlet stud bolts
I am puting on a new water inlet neck. The stud bolts are about 6'' long. The bolts that came with the inlet are bolts, about 21/2" long. The car is a 1931 fordoor model a. Does anyone know if the long stud bolts were the normal size studs used in the passenger car motors?
Rocky Rocket is offline   Reply With Quote
Old 07-06-2025, 03:01 PM   #2
Big hammer
Default Re: Water inlet stud bolts
I’am confused ? The water inlet is on the side of the engine and uses 2 1/2 bolts, the water outlet uses long head studs and screw into the head !
get a bigger hammer tap done
Old 07-06-2025, 04:24 PM   #3
bobbader
In other words, ..................... the WATER INLET is the small, angled pipe that mounts to the driver's side of the block, with the 2 & 1/2 inch bolts you have.
The WATER OUTLET (or as some of us refer to it, the "gooseneck") mounts to the top of the cylinder head at the front of the engine with the 6" studs you refer to.
Many folks assume the water flows from the top hose, through the "gooseneck", into the cylinder head and block, and exits the engine through the coupling on the driver's side of the block. In actuality, with the engine running, the water flows out the bottom radiator neck, up through the lower hoses and bypass pipe, INTO the side coupling (INLET), through the water chambers in the block and head, and is propelled (actually IM-PELLED) through the "gooseneck" (WATER OUTLET) up the top hose, into the top radiator neck, and, finally, deposited back into the radiator.
bobbader is offline   Reply With Quote
Old 07-06-2025, 05:10 PM   #4
1crosscut
1crosscut's Avatar
If there were studs on the side of the block that were used to mount the water inlet they are not correct. It is attached with bolts that have a 5/8" head.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-06-2025, 06:52 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
Big, I don't think you are the one that is confused...
Old 07-06-2025, 07:20 PM   #6
JayJay
I believe that the studs for the upper fitting (outlet, “gooseneck”) screw into the block and pass through the head. The head is sandwiched between the block and the gooseneck.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 07-07-2025, 07:08 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
If it is the water outlet fitting being discussed, here are some tips.
File Type: jpg Water Outlet Casting Differences 213kb.jpg (69.9 KB, 37 views)
File Type: jpg Water Outlet Installation Tip 241kb.jpg (76.2 KB, 39 views)
Bob Bidonde
Old 07-07-2025, 08:45 AM   #8
nkaminar
nkaminar's Avatar
I just use a gasket sealer and no gasket.
nkaminar is online now   Reply With Quote
Old 07-07-2025, 09:25 AM   #9
Rocky Rocket
correct It is the water outlet. The water outlet... I received had the two inlet bolts. it sounds like the supplier and myself both were confused. I couldn't find the long studs on Snyders site. Thanks for the correction. This forum is better than any book I've ran across and I have them all!
Old 07-07-2025, 09:36 AM   #10
Rocky Rocket
oh yea... great info Bob thanks for the pic'! The brown paper bag gasket and thin smear of Permatex Indian Head Gasket Shellac will be my attack plan!
Old 07-07-2025, 09:52 AM   #11
Y-Blockhead
Yes, a very thin smear of 'The Right Stuff'.
https://www.snydersantiqueauto.com/p...d=978670&cat=0
Old 07-07-2025, 11:26 AM   #12
JayJay
JayJay
