Old 06-26-2025, 10:53 AM   #1
mrraford
Default Testing Vacuum wipers at the work bench
I've been working on several vacuum wipers recently. Time to give them a test and tweak. Anybody have a suggestion for a cost effective vacuum source at my work bench?
mrraford is offline   Reply With Quote
Old 06-26-2025, 11:11 AM   #2
Canton_Model_A's
Canton_Model_A's's Avatar
Default Re: Testing Vacuum wipers at the work bench
you could get a vacuum pump from Hazard Freight. That might work
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 06-26-2025, 01:08 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
if you have a air compressor and can tolerate the noise a venturi vacuum pump is cost effective to buy new.
yYou could go to the you pull it junkyard and search the cars for booster pump.
some cars mostly european had a small vacuum pump for cruise control.
the cheapest is a piece of hose to suck on with your mouth.
And of course running gasoline engine usually can supply vacuum.
And the hand vacuum pumps.
A distributor machine usually has a adjustable vacuum pump too.
Old 06-26-2025, 04:52 PM   #4
nkaminar
nkaminar's Avatar
I use my vacuum pump that I bought for casting work. Search on Google or Amazon to find a low cost one.
Old 06-26-2025, 08:15 PM   #5
Big hammer
How much vacuum would a shop vac create ? Most everyone has one !
get a bigger hammer tap done
Old 06-26-2025, 08:38 PM   #6
2speed
Could you not just run a rubber hose from the manifold and hold the wiper in your hand while the car is running?
2speed is offline   Reply With Quote
Old 06-26-2025, 11:23 PM   #7
J Franklin
J Franklin's Avatar
Rubber hose to mouth?
Old 06-27-2025, 10:35 AM   #8
katy
katy's Avatar
The intake on an air compressor might work, would probably need a means to regulate it.
Old 06-27-2025, 01:00 PM   #9
nkaminar
nkaminar's Avatar
If you have a vacuum gauge you can test all the ideas that people have come up with. I don't think a mouth is a good tool for this application.
Old 06-27-2025, 07:08 PM   #10
rotorwrench
rotorwrench's Avatar
The 12-volt pumps for power brake vacuum are generally equivalent to the manifold air pressure of an automobile engine. They shouldn't break the bank on price. A mighty vacuum hand pump might work but your hand would get tired.
Old 06-27-2025, 08:51 PM   #11
John
John's Avatar
I have used one of the hand vacuum pumps for checking automotive vacuum controls. Just pump away and slowly the wiper will stroke and return.
John
John is offline   Reply With Quote
