#1 |
Good morning. I developed a backfire in our coupe again. Lack of power and loud cracks out the exhaust. Brought it home and put compressed air through the gas line and once again temporarily fixed the issue. I’m going to replace the
Pencil filter in the shut off valve. Is their a supplier that sells a particular one that works best or are they all the same? Thank you |
#2 |
I have always had good luck with the sediment bowl. If the fuel flow is low enough the crap settles out. If needed a filter can be added that is easy to change. I have always used the glass ones. Not sure what your car has but you may want to consider the glass sediment bowl.
Clarification: I was suggesting the sediment bowl instead of the filter in the bottom of the tank.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 06-05-2025 at 09:51 AM. |
#3 |
I have the glass sediment bowl with wix filter. It’s the gas valve under the dash. That filter I’m assuming needs to be replaced
#4 |
Hi, Snyders sells a "Fuel Shut Off Valve" with a "A-9193 Screen"; $34.00. I have both in the last year and they work as advertised-"Wont Leak!". Definitely a major upgrade as I went thru 2 different valves in the previous 7 years.
#5 |
Hi again, I should have mentioned that the A-9193 TX screen has to be separately purchased with the valve; cost is $5.60.
#6 |
Ruth "Sometimes you really DO need to read the whole thread" |
#7 |
It appears you have a lot of loose sediment, rust, or whatever in your tank. Maybe you should park on an incline and at minimum drain it and flush it a couple of times before installing filters.
#8 |
Maybe you need a "dirty leg":
#9 |
I buy 6 pencil filters at a time and always have them on hand for the "next A"
I also use the bowl on the firewall with a magnet in the bottom. Everything seems to work pretty well. This is after a major flush upon purchase of a "new" car. |
#10 |
I will try and clean the tank. It seems decent but who knows what settles down their. My shut off valve works fine. Is it ok to just change the filter?
#11 |
yes or if you clean the tank reinstall the existing pencil filter that you have.
www.whidbeymodelaclub.com |
#12 |
Thank you everyone!
#13 |
When I purchased my ball valve from Snyder's last year they were also out of the pencil filter then I used my older style round pencil filter and a little bit of JB weld on the new valve and everything worked fine!!!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#14 |
The tank in my Victoria was thoroughly cleaned before installing it during the car's restoration. However, fine sediment continues to be trapped in the bowl. I have a pencil screen in the gas shutoff valve and the glass bowl is completely stock. My expectation is that there will always be some sediment in the gasoline.
Bob Bidonde |
#15 |
I put this filter the glass bowl. https://www.mikes-afordable.com/product/A9156A.html Mike's says tank filter is in stock now 6/6/2025.
.https://www.mikes-afordable.com/product/A9193T.html
It's not the destination ,it's the journey . Last edited by stevemclark; 06-06-2025 at 07:58 AM. |
#16 |
I use this WIX filter https://www.amazon.com/dp/B000CSD2BE...d_asin_title_1
