Old 04-23-2025, 07:55 PM   #1
fordv8j
fordv8j's Avatar
Default Carburator spacerdo the spacer under the carb
Does a spacer under carb help; shut car off for a little while; don't want to start
fordv8j is offline   Reply With Quote
Old 04-24-2025, 12:02 AM   #2
ford38v8
ford38v8's Avatar
Default Re: Carburator spacerdo the spacer under the carb
Richard, the spacer you ask about is an insulator against heat transfer from the manifold. It provides a minimum benefit in that way, the best method is to open your hood when you park for lunch or whatever, to ventilate the engine compartment, as modern fuel will boil off, evaporate from the carb as well as from the fuel pump while parked, pump loses its prime, carb is dry. Try a squirt bottle directly into the carb vent to give it a head start.
Alan
Old 04-24-2025, 02:00 AM   #3
tubman
tubman's Avatar
If it's a 94 type carburetor, it may be a leaking power valve.
tubman is online now   Reply With Quote
Old 04-24-2025, 10:06 AM   #4
JayChicago
JayChicago's Avatar
In the boiled-off scenario, doesn't start because it's too lean. In the leaking power valve scenario, it's too rich. Suggest you try a hot start with pedal to the floor to pull in more fresh air. If that shows an improvement, indicates was too rich.
JayChicago is offline   Reply With Quote
