Old 04-21-2025, 01:49 AM   #1
mercman from oz
mercman from oz's Avatar
Default 1934-1935-1936 Ford Spare Wheel Covers.
While the 1934 and 1935 Covers appear the same, they are different.
Old 04-21-2025, 06:30 AM   #2
mercman from oz
Default Re: 1934-1935-1936 Ford Spare Wheel Covers.
1934 and 1935 Ford Spare Wheel Covers - They are different
Old 04-21-2025, 08:59 AM   #3
deuce lover
deuce lover's Avatar
Besides the stainless being wider on the 33,34 the attachment hdwe uses threaded stud plates.The 35 have twist clips.
deuce lover is offline   Reply With Quote
Old 04-21-2025, 04:41 PM   #4
mercman from oz
1934 and 1935 Ford Spare Wheel Covers compared.
The most obvious difference is the width of the stainless ring, but that is only the start.
If you look at the picture of the underside, you can see that the stainless ring is held in place by a small threaded bolt on the 33/34 cover.
On the 35 cover - right, the hole is smaller and the stainless ring is held in place by little clips.
Apart from the size of the hole to support this Stainless ring, the actual covers are also different.
The inner edge of the 33/34 cover is rolled and very substantial.
However, the inner edge of the 35 cover is not rolled and easy to get out of shape, as you can on this example.
Old 04-22-2025, 04:39 PM   #5
mercman from oz
1936 Ford Spare Wheel Cover. Can't confuse this one.
Old 04-22-2025, 06:36 PM   #6
FlatheadTed
FlatheadTed's Avatar
A bit of topic lf your interested !I body worked my Chrome trim for my 35 in the day by making a T shaped bit of flat steel welded to a 1/4 round rod . I shaped the flat bit to slide in with a curve the same shape as the chrome .while holding the Anvil in the vice I fed the chrome around it tapping the low spots face with a body hammer. it was near flat in some places .I would spray it black from time to time then block sand it with 600 grit working my way down to a finer grit, then buffed it. Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-22-2025, 11:15 PM   #7
Brian
Brian's Avatar
then there is another style of 36 cover......
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 04-23-2025, 01:45 AM   #8
Randy in ca
Randy in ca's Avatar
1936 (late) Standard Wheel Cover:
Randy in ca is offline   Reply With Quote
Old 04-23-2025, 05:16 AM   #9
mercman from oz
Further to Randy's comment, 1936 Ford Standard Spare Wheel Cover.
I have never seen one here in Australia.
Did all 1936 Ford Standard models get this style Cover?
Old 04-24-2025, 08:03 AM   #10
rockfla
rockfla's Avatar
Here is one on Ebay right now for sale
https://www.ebay.com/itm/38788758244...Bk9SR5iNoP7MZQ
Old 04-24-2025, 11:22 AM   #11
petehoovie
petehoovie's Avatar
1936 FORD Locking Spare Tire Cover Coupe Sedan Flathead No Key 1930s 27"
US $149.95
