Old 04-10-2025, 11:51 AM   #1
tommyleea
Default 2 Door Ranchwagon Exhaust
53 Ford Ranchwagon with Flathead V8. Is there a way to make the exhaust for a sedan work on my Ranchwagon? The pictures I have seen look similar, but not sure if it is just the tailpipe that would be different, or the entire system. Thanks if you know.
tommyleea is offline   Reply With Quote
Old 04-11-2025, 08:46 AM   #2
51504bat
51504bat's Avatar
Default Re: 2 Door Ranchwagon Exhaust
From what I understand the tail pipe location for a wagon needs to exit to the side so that exhaust fumes don't get sucked backed in through the rear window/tail gate as shown in this photo. I believe that on sedans the tail pipes exit straight back under the rear bumper.
File Type: jpg BB7ACE64-3E66-44C5-81AB-8E129675978D.jpg (102.8 KB, 163 views)
Old 04-11-2025, 09:41 AM   #3
tommyleea
Thanks for the info. I imagine something can be rigged up to extend/reroute the tailpipe if that is the only difference. Worth a shot. Cheers. TommyJ
Old 04-11-2025, 10:33 AM   #4
petehoovie
petehoovie's Avatar
Old 05-03-2025, 10:06 AM   #5
tommyleea
Well, the Ranchwagon frame/suspension must be different from start to finish. The exhaust pipe that connects to the exhaust manifold doesn't even fit. It hits the idler arm on the Ranchwagon, so it won't enter the frame port holes. The muffler bracket looks the same, but it is different also. It will work because the rubber arms swivel, but it is narrower. These parts were for a 4 door. I guess I will go to a muffler shop and get an exhaust made up. Thanks TommyJ..
Old 05-03-2025, 01:41 PM   #6
Bob C
I found this in the Ford Parts Book.
Muffler inlet pipe AC 5246-A 1952-53 except conv.
Muffler A9A 5230-A 1949-53
Muffler outlet pipe B2A 5255-B S/D & S/w 1952-54
Old 05-03-2025, 07:27 PM   #7
paul2748
paul2748's Avatar
Heed the warning about positioning the pipe pointing to the back and not to the side. It could save your car and your life.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-04-2025, 08:19 AM   #8
tommyleea
Thanks for the info Bob. I can't find a picture of that muffler inlet pipe, but it must be a separate pipe between the exhaust pipe and the muffler.?
Old 05-04-2025, 09:02 AM   #9
kurt v
Have you tried Walden's mufflers ?
kurt v is offline   Reply With Quote
Old 05-04-2025, 10:37 AM   #10
tommyleea
I have looked there, but didn't see the ranchwagon/station wagon listed.
Old 05-04-2025, 10:49 AM   #11
Bob C
Here you go. https://waldronexhaust.com/product/1...st-w1-muffler/
Just go to body style and check station wagon
Old 05-04-2025, 11:13 AM   #12
38 coupe
38 coupe's Avatar
Be careful which exhaust manifold is in your ranch wagon. The original 52-53 manifold from a 215 has the exhaust exit straight down. The more common manifold angles back at a 45 degree and was used from 54 to the end of 223 production, I think. The manifold to muffler pipe needs to match which manifold you are running.
Old 05-04-2025, 01:40 PM   #13
tommyleea
Thanks Bob..Got it.
Copy..Thanks
Old 05-06-2025, 01:14 PM   #14
mfirth
I had a friend who had several wagons and did his duals like post #2 did on that wonderful
1955 wagon. It was o k, but do TAKE HEED of straight out the back !!!!
mfirth is offline   Reply With Quote
