#1 |
Oil pressure and water temp are the gauges I am trying to hook up. How do you hook up the two gauges to the electric and where does that connection occur? I am piggy backing the two together but then it needs to go to a power source that will only be turned on when the key is turned on. Thanks in advance. They are mechanical gauges.
