Old 03-29-2025, 08:06 PM   #21
Ayers1
Ayers1's Avatar
Default Re: oil Pressure & Water temp. gauges
No, I run a stock 6 volt positive ground system. It has been suggested on previous threads that if you run everything through the switch then you should add a relay to take the load and keep the switch from burning up.
Steve,
Proud owner of
28 Fordor, been in family since 63
30 Tudor
31 S/W Town Sedan
Skyline Chapter MAFCA, MARC
Ayers1 is offline   Reply With Quote
