#1 |
Going to put a pair of door pull ring on inside my 34. Are they screwed in with sheet metal screws and where should they be placed on the door?
#2 |
I used riv-nuts instead of sheet metal screws on my car as I believe the fasteners will have a better chance of staying tight under the load of pulling the door shut.
Can't say where to put them; but maybe about the same place the grab bar is on deluxe garnish. |
#3 |
There were D nuts on the inner door skin. NAPA used to sell rivet nuts and you crimp them by tightening the allen bolt.Harbor Freight sell a rivet nut kit BUT the nuts are aluminum.The force of pulling might compromise the threads? Only 33's had them.Here is a pic of an original '33.
#4 |
Yes I know the 33 had them and 34 didn’t. Figured it was better then pulling on door handle. The straps were not there when I got the car. The rivets sound like good idea. Thanks.
#5 |
34 had pull rope cords or early Std had pull built into the garnish
#6 |
#7 |
Mike
Your coupe is triple sweet!!! Just fantastic |
#8 |
Does the door pull ring bolts go underneath the window trim or right below the trim?
#9 |
that's a door pull on the molding. Mine is an early 4 cyl car. newc
#10 |
The part of the bracket with the 2 screw attachment holes that it pivots on is concealed by the lip of the garnish moulding. Maybe a member here with a 33 can give you a precise location of where to fix the rivet nuts (if that is what you use). Here is a pic of the drivers door on a tudor I had with the panel installed .It was from a LBB kit that I bought in Nov 2016. I later installed the ring.
I just realized that if your car is a Deluxe the garnish is different . The bracket and ring will have to be lower. Last edited by deuce lover; 04-01-2025 at 12:11 AM. |
#11 |
Looked at a33 it has holes where the pull goes.
#12 |
#13 |
Holes are not in the garnish moulding .Here is a tudor door on the HAMB.You can see the D nuts on the panel
#14 |
