Old 03-27-2025, 04:52 PM   #1
Abchoppers
Abchoppers's Avatar
Default Intermittent no start
56 Merc, new battery and new starter
Sometimes I will intermittently get no noise at all when turning the key. My fuel pump is wired with the key on and I hear it pumping every time even with the random no starts. If I try again right away the car will start.
Maybe ignition switch or body ground? I just don’t want it to get worse and not start one day and I’m stranded
Thanks for any thoughts
Abchoppers is offline   Reply With Quote
Old 03-27-2025, 07:38 PM   #2
paul2748
paul2748's Avatar
Default Re: Intermittent no start
Check and clean all electrical connections, including the ones at the starter switch. Possibly a bad starter switch
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-27-2025, 08:21 PM   #3
dmsfrr
dmsfrr's Avatar
Do check the battery to engine and engine to body Ground cables for clean & tight connections. Also the body ground of the starter solenoid. For some reason they're easily forgotten.
dmsfrr is offline   Reply With Quote
Old 03-28-2025, 07:55 AM   #4
GLAmes
GLAmes's Avatar
The neutral safety switch might need adjusting.
'54 Skyliner. As close to original as I could restore it to.
GLAmes is offline   Reply With Quote
Old 03-28-2025, 07:56 AM   #5
Ford blue blood
Ford blue blood's Avatar
Listen to see if you can hear/feel the solenoid when the key is in the start position.
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 03-28-2025, 09:28 AM   #6
KULTULZ
KULTULZ's Avatar
Question Re: Intermittent no start
Are you describing engine NO-CRANK (does it crank) or NO-START?
Is the electric fuel pump a primer or transfer install (via mechanical pump)?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 03-28-2025, 12:18 PM   #7
Abchoppers
Abchoppers's Avatar
Checked all connections and all seem good, they’re all fairly new. I’ll check the starter solenoid next along with the neutral safety switch. Thanks for the ideas
Old 03-28-2025, 12:19 PM   #8
Abchoppers
Abchoppers's Avatar
It’s a no crank, electric pump is a primer. I only mentioned that because the ignition does turn on the fuel pump, thinking maybe that rules out ignition but I don’t know
Old 03-28-2025, 12:47 PM   #9
KULTULZ
KULTULZ's Avatar
Arrow Re: Intermittent no start
With a TEST LIGHT, check for current at the COIL (+)/RESISTOR when the key is turned to RUN.
Then TEST LIGHT on the "S" pin on the starter solenoid when key turned to START.
How is the pump wired, continuous run on IGN SW on RUN?
File Type: jpg Starter Solenoid - 12V - B6A 11450-A _3 - (4 Pin).jpg (193.2 KB, 5 views)
Old 03-28-2025, 01:42 PM   #10
Abchoppers
Abchoppers's Avatar
Test light shows hot a coil terminal with key turned to run, also shows hot on starter solenoid in start position, yet right now the car is also starting normally. I’ll try and test these again next time I get a no crank, it’s just so random it can be once and not again for days or 5 times in a row.
The fuel pump is wired from a relay to a toggle switch, to the ignition switch on continuous run. The car is also running very rough and is breaking up on acceleration, I changed out coil but no luck. Not sure if it’s related
Old 03-28-2025, 02:06 PM   #11
Abchoppers
Abchoppers's Avatar
I checked the neutral switch on the steering column, I found a wire that was jumping two wires together, I’m guessing this is to bypass the safety switch since I just found out the car starts in all gears. So while not a good thing, it’s prob not the problem with the no crank. I feel like it’s something electrical failing that is also causing rough idle and acceleration break up
Old 03-28-2025, 06:14 PM   #12
KULTULZ
KULTULZ's Avatar
Exclamation Re: Intermittent no start
I found a wire that was jumping two wires together ...
Once someone butchers a wiring harness, anything could have happened.
You can by-pass the IGN-START SYSTEM by running a jumper between the starter solenoid and coil and then jumping the solenoid. But it bypasses the NSS, so you have to be on your guard.
