#1 |
Anyone have a number on just how many Amps a 6V flathead starter draws when it turns under load? Stock configuration
#2 |
Found this from 2021 on the Forum here: On 6v the draw should be under 450 amps
#3 |
Wow. WOW! Like less than half of that. Over 200 amps would mean bad condition of the starter itself, the cables, the battery, or a new rebuild with tight bearings.
Alan |
#4 |
Torque RPM Volts Amps 4 ft. lbs. 1070 4.6 200 8 " 660 4.3 340 12 " 300 3.65 465 14 " Lock 3.5 500 Last edited by Bob C; 02-17-2025 at 06:58 PM. |
