Old 02-14-2025, 03:52 AM   #1
mercman from oz
mercman from oz's Avatar
Default 1933 Ford Deluxe V8 Phaeton in France
This 1933 Ford Deluxe V8 Phaeton is shown in the Nov/Dec 2024 issue of V8 Times.
It is Right Hand Drive, and was obviously built in Australia.
Old 02-14-2025, 04:02 AM   #2
mercman from oz
Default Re: 1933 Ford Deluxe V8 Phaeton in France
You may be wondering why I stated that this 1933 Ford Phaeton (Post 1) was built in Australia?
Take a look at the 4 separate Door Hinges on this 1933 Ford Phaeton, plus the false panel above the Running Boards.
The above illustration shows the Centre Pillar, Doors and False Panel on an Australian 1934 Ford Phaeton.
That is why I suggested that it was originally built in Australia.
Old 02-14-2025, 04:10 AM   #3
mercman from oz
Compare this photo of the Doors and Centre Pillar on this American 1934 Ford Deluxe Phaeton.
Notice that both Doors swing on the same Hinges, unlike the Australian design.
There is no False Panel above the Running Boards.
No body part except for the Cowl is interchangeable between these two countries of manufacture.
Old 02-14-2025, 07:39 AM   #4
rockfla
rockfla's Avatar
Trevor
Thank you for sharing this interesting information on the Aussie phaetons....The 33 you posted pictures of has body color fenders....what that standard practice in Australia OR an owner decision??? ALSO I noticed the Aussie Phaeton with what looks like"different" style door handles or is it just a funky reflection of them???
Old 02-14-2025, 09:16 AM   #5
uncle buck
uncle buck's Avatar
The picture is fuzzy , but the handles look like 32 handles to me.
uncle buck is offline   Reply With Quote
Old 02-14-2025, 10:38 AM   #6
deuce lover
deuce lover's Avatar
33 roadster and phaeton outside door handles are identical to 32's except for the length of the shank.The end of the shank is threaded for securing the inside handle which a 32 does not have.
deuce lover is offline   Reply With Quote
Old 02-14-2025, 10:48 AM   #7
rockfla
rockfla's Avatar
Sheldon
Thanks for the continuing education.....Amazing all the detail changes from year to year. Blows me away!!
Old 02-14-2025, 04:40 PM   #8
mercman from oz
The Green Phaeton in Post #2 is actually an early production 1934 Ford Deluxe V8 Phaeton.
It has the lowest Body Number for a Australian 1934 Ford Phaeton.
There was no break in numbers starting with the 1933 models.
All Body Numbers lower than this example are 1933 models.
As such, they were fitted with 1932-1933 style Door Handles.
Old 02-14-2025, 04:41 PM   #9
mercman from oz
Exterior Door Handle for 1932, 1933 and early 1934 Australian Open Fords
Old 02-14-2025, 04:41 PM   #10
mercman from oz
Exterior Door Handle for late 1934 Australian Open Fords
Old 02-14-2025, 04:47 PM   #11
mercman from oz
Interior Door Handle on 1933- 1934 Australian Open Fords
Old 02-14-2025, 05:15 PM   #12
alchemy
alchemy's Avatar
Even the cowls are different.
alchemy is offline   Reply With Quote
Old 02-14-2025, 05:57 PM   #13
mercman from oz
Modification to Australian Cowls on Australian 1933 and 1934 Fords.
The only difference in the Cowls that I am aware of is that the bottom of the original imported Cowls were pie-cut to raise the bottom moulding to line up with the False Panel on Australian 1933 and 1934 Fords.
Refer to above photo showing the different angle this moulding takes after it was modified.
However, before this modification, they started out as the same
Old 02-14-2025, 06:06 PM   #14
mercman from oz
American 1934 Ford Cowl showing Moulding in original position on top of Running Board.
Old 02-14-2025, 09:25 PM   #15
DavidG
DavidG's Avatar
Sheldon,
To avoid or perhaps create confusion, the North American Model A - '32 open car outside door handle shank are threaded like the '33 open car handles. It's the shank length that differs with the shank on the '33 handle nearly 3/4" longer.
I wish the vendors would correct their listings as they list them all as being equal, which they are not. Reproductions of the '33 handles haven't been available for years.
Old 02-14-2025, 09:36 PM   #16
Karl Wescott
Karl Wescott's Avatar
This appears to me to be the exterior style of 1932-34 closed cars with the mounting bezel of the 1932 3 Window/1933-34 closed car style. My understanding is the US "1934" open car handle did not have the pronounced "eyebrow" of the closed car handle and used the narrow bezel similar in dimensions to 1929-33 open cars.
The inside handle appears to me to be the same or very close to what was used US 1929-31 and 1933-34 open cars, and was also used on the panel truck rear doors 1929-1956 (or even later).
Karl Wescott is offline   Reply With Quote
Old 02-15-2025, 01:46 AM   #17
highbeams
highbeams's Avatar
Thanks much for this!
highbeams is offline   Reply With Quote
Old 02-15-2025, 02:16 AM   #18
DavidG
DavidG's Avatar
Karl,
And station wagons of the era.
Old 02-15-2025, 06:19 AM   #19
torpedo
torpedo's Avatar
Hello Mercman and Barn members.
Thanks for relaying the V8-Times article.
I am the proud owner of this car. I confirm it is right-hand drive !
The car was built in Canada most probably Q1 1933, confirmed by RG127 president soon after purchase in 2000.
I try to keep it as original as possible but had to fit repro parts as and when since NOS parts are very difficult to source in Europe.
Happy to share more details to those interested.
Take care
Flathead enthusiast - 1933 Phaeton
torpedo is offline   Reply With Quote
Old 02-15-2025, 11:11 PM   #20
mercman from oz
Hi torpedo, I love your 1933 Ford Deluxe V8 Phaeton.
Can you please tell me the Body Number of your car.
This is the location of the Body Number on 1933 and 1934 Ford Cowls
Please add a colour photo of your 1933 Ford to this Thread.
Regards Mercman <><
