Old 02-13-2025, 05:36 PM   #1
Ayers1
Ayers1's Avatar
Default Can an engine run with camshaft 180 degrees off?
I can do a lot of things on an A but I've never rebuilt an engine before. Forgive me for what may be a dumb question. Back several months ago I had the engine out of my car because it was knocking. When I opened it up I found several teeth missing/chewed up on the timing gear. I turned it around to TDC and the dots lined up on the cam and crank gears. I replaced the gear, checked bearing clearance and put it back in the car. Last week I tried to start it and finally figured out that I had to set the time to #3 cylinder to get it to run. It doesn't run great but it runs. I can tell that the engine was rebuilt before I bought it last year so, should it run with the cam 180 degrees out? Thanks,
Ayers1 is offline   Reply With Quote
