It depends on what is 180 out of time
Crank 180 out no Cam at 180 is one revolution on crank so no problem J
As Carroll Smith wrote; All Failures are Human in Origin. |
#2 | |
![]() Quote:
in my engine building day, i always set it up so first crank of the starter and it was a V-ROOMM! every time! TDC, fuel in carb, good batt, and distr set and checked to produce the spark at plug with a lil twisty... by hand, key ON. if the engine did not immediately start and come to life for its break in run i considered the first start up a failure. keyword: immediate! no variances!!~ ![]() I did not have failures!! failures not allowed in my shop! ![]()
"My Model A... work never ends, only the day ends!" |
I had a similar problem and after some time, I discovered that the distributor gear had loosened on its shaft and screwed up the timing. Changed it out and problem solved.
