Old 02-07-2025, 09:27 AM   #1
TomC750
TomC750's Avatar
Default Chevy cyl numbering
Odd question to ask on the Ford Barn forum, but here goes. I had some machining done on my 8NV8 tractor engine. The shop took the valves out in the process. The owner thinks their employee did not understand the flathead numbering system and numbered the valves (nicely packaged up) and numbered like a small block Chev. So what is that numbering system?
I will install a few according to that and check clearances, then put the rest in and check again.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
