#1 |
Hello
Ford flathead 8ba With 2 Stromberg carburetors Does the pcv valve have to be connected to both carburetors or just one? Thanks for reply |
#2 |
The PCV will work perfectly if its located anyplace below the carburetors throttle plates.
You only need to have one connection overall its best anyplace in the intake plenum to get the vacuum signal needed for the PCV to work. Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#3 |
Ronnieroadster thanks for your reply!
#4 |
If you are adding a PCV to a flathead make sure you are pulling from the correct port. I have seen some PCV installations on a flathead that resulted in pulling dusty outside air into the oil pan slot, achieving the opposite of the desired goal.
#5 |
Will this work
Mount the vacuum base on one carburettor. Connect the pvc valve to this vacuum base? Does it matter which of the carburetors I connect? Will use Offenhauser 1075 intake |
#6 |
#7 |
38 coupe which port will you recommen?
#8 |
Found a guy who makes spacers for Stromberg97
thinking 1" or 4" and connect pcv valve to spacer. Could this be a better choice? |
#9 | |
Ronnieroadster
#10 |
I wish I could post pictures but sadly I'm a dinosaur. I have done quite a few Flathead s with a PCV and I think how we do it not only looks good but works great.
#11 | |
#12 |
Tubman I'll send you 2 different versions.
#13 |
https://www.jalopyjournal.com/forum/...#post-15011896
See post number 5 for photos and info on what I did for my 8ba
Making the simple complicated for over 30 years. |
#14 |
Here are "Krylon32"'s photos :
#15 |
Thanks Tubman. I need to add the 3 FH intakes in the pictures plus several others were built for me by Bob at Baxter Ford Parts in Lawrence Kansas. The intakes are all Offenhauser.
#16 |
#17 |
Here's a pretty comprehensive thread about flathead PCV systems that was put together by our own "V8Coopman" a few years ago I suggest that anyone contemplating a PVC system review it before jumping in with both feet.
https://www.fordbarn.com/forum/showt...take+pcv+valve |
