Old 01-15-2025, 09:44 PM   #1
Hoodooman
Default Valve seat cutter and proper pilot
Can anyone recommend a 239 flathead pilot and seat cutter? I've heard new way is good? Just planning on a valve job using the old seats.
Thanks!
52 Ford Customline Fordor
Hoodooman is offline   Reply With Quote
Old 01-15-2025, 10:04 PM   #2
Lawrie
Lawrie's Avatar
Default Re: Valve seat cutter and proper pilot
I have the new way cutters, they are very nice and easy to use, do a great job .
I have a special pilot the engages with the valve guide bore as well as the lifter bore.
Lawrie
Lawrie is offline   Reply With Quote
Old 01-15-2025, 10:47 PM   #3
flatjack9
flatjack9's Avatar
I have the same system as Lawrie. They are Neway.
Old 01-15-2025, 10:59 PM   #4
tubman
tubman's Avatar
Lawrie
Lawrie,
Is the "special pilot" a Neway product or something special from another source? I have been looking at these for a while.
Denny
Old 01-15-2025, 11:58 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
Hey Lawrie, was curious of the diameter of the pilot you have? I have both a Sioux and a Kwikway pilot (for their standard seat holders) - was wondering if they would work with the Neway stuff?
Old 01-16-2025, 01:56 AM   #6
fortyonerag
fortyonerag's Avatar
I used a Neway Cutter on a recent build. I kept everything scrupulously clean and it seemed to work out well.
FWIW, I used:
CU616 30/45deg valve seat cutter
Pilot tool PEM150-8.5mm
Wrench TW505.
fortyonerag is offline   Reply With Quote
Old 01-16-2025, 11:43 AM   #7
flatjack9
flatjack9's Avatar
The pilot I have is not Neway and works just fine. Same one I used when I used to use stones. Sioux
Old 01-16-2025, 11:53 AM   #8
Bored&Stroked
What are you guys seeing as far as the quality of the seat finish and concentricity? Anybody use a seat mic afterwards to see if there is any run-out?
I'm used to stones where you have a really nice concentric and almost polished seat. I'd love to see some close-up pictures if any of you have them. I might be able to use my Kwik-Way Seat cutting setup with one of these Neway cutters to do the seat work (depending on the quality of the finish and concentricity).
Old 01-16-2025, 11:55 AM   #9
Bored&Stroked
Isn't a Sioux pilot .385 in diameter?
Old 01-16-2025, 07:38 PM   #10
meric42
meric42's Avatar
I bought this one from Amazon and found it worked just fine for my purposes, but I'm not a mechanic
https://www.amazon.com/dp/B071WW28KN...fed_asin_title
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 01-16-2025, 08:51 PM   #11
Hoodooman
Thanks. May I ask What pilot you used?
Old 01-16-2025, 08:52 PM   #12
Hoodooman
Old 01-16-2025, 08:55 PM   #13
Lawrie
Lawrie's Avatar
Pic of my pilot,
it is made by W&B (warren and Brown ) has W&B V8 stamped
pilot is .375 top diameter is 1.032 bottom dia 1.000
Lawrie
Old 01-16-2025, 09:12 PM   #14
Hoodooman
Pic of my pilot,
Lawrie
Thank you!
Old 01-16-2025, 11:14 PM   #15
KiWinUS
KiWinUS's Avatar
Pic of my pilot,
Lawrie
I have the exact same Lawrie and also my Made in Australia Warren Brown Syncro seater set I bought over from home to the US with me. I love it and have tried the Cutters mentioned above but in my opinion the stones do a much better job and more concentric seat. I have even gone head to head with the salesman of the cutters and embarrassed him.
Stones B&S (Dale) are my preference even if they are slower.
Lawrie I sure wish I could bring my Dad’s Wolf valve refacer over also as I believe it is as good as it gets.
Old 01-16-2025, 11:21 PM   #16
Lawrie
Lawrie's Avatar
Kiwi, I just slung out an old set of stones from my dads old US made set, let me know as they are still in the bin,
will get some pics
Lawrie
Old 01-17-2025, 12:32 AM   #17
Lawrie
Lawrie's Avatar
This is what I use to check the seats
Old 01-17-2025, 03:58 PM   #18
Ken/Alabama
Ken/Alabama's Avatar
I have a Hall eccentric seat grinder . Does a fantastic job but slow.
Ken/Alabama is offline   Reply With Quote
Old 01-17-2025, 07:06 PM   #19
GB SISSON
GB SISSON's Avatar
This is my .375 B&D with extraction handle. I used this pilot without the handle on two valve jobs and it could be a pain wringing it back out. Last year when I bought my lathe in Seattle the guy had a bunch of 'outdated' automotve gear and asked if I wanted any of it. There was a Sioux seat grinder and a Sioux setup for counterboring the block for hard seats. In the seat grinder kit was this snap-lock handle for my B&D and of course it fit nothing in the Sioux kit. Just my lucky day.
Old 01-17-2025, 08:02 PM   #20
38 coupe
38 coupe's Avatar
Totally off topic, but I have to ask: GB, why do you have a bottle of "instant rust"?
