Old 12-08-2024, 07:49 PM   #1
41SupDelux
Default 1941 Ford Super Deluxe Radio Antenna Beneath Car
Good evening, gentleman.
I recently pulled the radio out of my 1941 Super Deluxe to pull it apart and see how it looked. All the components seem to be original. I don't know whether I'll try to replace all of the capacitors and other related components, but in looking at tackling this project, it made me curious about the antenna. I noticed shortly after I first bought the car that the antenna (definitely not stock) is attached to the frame beneath the driver side door - it's an extremely long antenna, with a spring base. My question is: where would the original antenna be? There isn't a spot for it on the roof nor the fenders, so I'm curious where it would have been. Was it ever common to put radio antennas beneath the car?
41SupDelux is offline   Reply With Quote
Old 12-08-2024, 08:01 PM   #2
TJ
TJ's Avatar
Default Re: 1941 Ford Super Deluxe Radio Antenna Beneath Car
The stock antenna with a factory installed radio is a roof style antenna. I think you may have an aftermarket radio.
Old 12-08-2024, 08:27 PM   #3
41SupDelux
Radio appears to be stock, however the antenna wiring was routed underneath the car. Just curious why there isn't a place on the car for a stock antenna.
File Type: jpg 54bec0d0-ca0a-44de-9435-10ba9ff2b3a0.jpg (54.9 KB, 37 views)
Old 12-08-2024, 09:43 PM   #4
TomC750
TomC750's Avatar
My '41 Mercury has a delete plate on the dash and no antenna hole on the body.
Tom
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 12-09-2024, 12:58 AM   #5
FortyNiner
FortyNiner's Avatar
One of the aftermarket solutions in '46 used a cowl mount like mine.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 12-09-2024, 05:31 AM   #6
Ggmac
41s with factory radio had the antenna go through the roof centered in the middle of the dash . You could adjust its while driving.
2 41s I’ve owned, had the cowl mounted antenna and one recently purchased 41 had the normal 60s style, a hole through the top passenger side cowl .
Ggmac is offline   Reply With Quote
Old 12-09-2024, 07:58 AM   #7
fortyonerag
fortyonerag's Avatar
The threaded connection on the top of the radio is the antenna connection. The antenna connects through the top of the dashboard and feeds to the top of the windshield frame on the inside. The antenna mounts on a swivel on the outside centre of the windscreen at the top.
fortyonerag is offline   Reply With Quote
Old 12-09-2024, 03:10 PM   #8
meric42
meric42's Avatar
Here is how the original antenna was supposed to be fitted.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 12-11-2024, 10:27 AM   #9
farmertom
farmertom's Avatar
41SupDelux,sounds like the antenna u speak of is possibly a cb whip antenna.possibly one of the car owners didn't want to drill the body to install a correct antenna. possibly that whip did bring a very close radio station that only mattered. Tom.
farmertom is offline   Reply With Quote
Old 12-13-2024, 11:51 AM   #10
corvette8n
corvette8n's Avatar
Here’s how I shortened mine, but the installation is still in the original location.
https://www.fordbarn.com/forum/showthread.php?t=256226
