Old 11-25-2024, 06:52 AM   #1
KMBeers
KMBeers's Avatar
Default Universal Joint Install Question.
I posted this question in another thread and only got 1 response so I moved it here to see if there are other views. I am installing my engine in my 29 Tudor and I was just finishing my Universal Joint cover instal and I have a question about the proper way to install the bolts. Les Andrew’s book shows the bolts in the flange being installed towards the rear, however there is not enough room to install the bottom bolt that way so I have it facing front. My car is not a Fine Point car but I am curious if the way I have them in the pictures is correct or should they all face the same direction (towards front). I am leaning towards having all of them the same way but I wanted to see what others have done. This is not a big issue but if there’s a “right way” I would prefer to go that way. Pictures attached
KMBeers is offline   Reply With Quote
