#1 |
Super Moderator
Guys, I'm having an issue getting my aluminum 2-blade fan to seat correctly on a new "leakless" pump from Mike's Affordable.
I have read a bit about "new" pump shafts having incorrectly ground tapers. I'm thinking of buying one of their 4-blade fans. What might I be getting myself into here? Thanks men! Mike
#2 |
I am not sure what the problem is but what makes us think a four bladed fan is going to fit better than your two bladed fan if the shaft taper is incorrect?
The Master Cylinder Enjoying life at the beach in SoCal... |
#3 | |
Super Moderator
I have read numerous accounts of the reproduction pump shafts being made incorrectly. Do I have one? I'm simply not sure at this time. I am attempting to figure out exactly what the issue is.
#4 |
There was a time also when the taper on the aluminum fans was wrong and did not fit the shaft taper of correct shafts!
I am sure that some of these bad parts are still out there causing problems. |
#5 |
if the fan hub is hitting the snout of the water pump, take a little off the pump to allow the fan to move back more on the shaft.
#6 |
#7 |
Here is a link to some of the problem shafts.https://www.fordgarage.com/pages/waterpumpshafts.htm
I put some valve grinding compound on the shaft and lap it to the fan. |
#8 | |
Super Moderator
I do know for certain the tapers do not match.
#9 |
I think I would borrow a different fan and try it on the pump. That will tell you where the problem is.
Charlie Stephens |
#10 |
Before you do anything, what did Mike's say when you called them about your problem?
#11 |
Super Moderator
Charlie, I am currently attempting to locate a Ford fan at this time.
#12 |
Super Moderator
They simply could not believe there is a problem with the pump.
#13 |
Sounds like the guy you spoke with used to work for Bob Drake
Making the simple complicated for over 30 years. |
#14 |
Super Moderator
Ya know, I was a bit surprised as they (Mike's) have been pretty darn good all along.
#15 |
#16 |
The aluminum 2-blade fans are notorious for not fitting on the water pumps because they rub on the snout of the water pumps. Snyder’s instructions (https://www.snydersantiqueauto.com/c...INUM%20FAN.pdf) talk about this, and Snyder’s should know, they manufacture these things for all the vendors. The solution is to turn or grind down the snout of the water pump housing. I’ve had to do this to four water pump housings in the last two years, and have built a jig to clamp an assembled pump in the lathe to make it quick and easy. I turn the nose to about 1.630" (1-5/8"+) from the nose to where the boss for the front grease fitting comes out.
If you don’t have the pump apart and can't chuck it up in a lathe, the way to do this is to put fresh paint on the snout, then slip the fan onto the shaft and turn it as you very lightly press on it. It will rub and leave a mark on the pump where it hits. File or grind that down, then continue. When you have it turning freely, take just a bit more off to allow for heat expansion. Repaint the snout and you’re ready to go. The reason this happens, especially with “leakless” pumps, is that the bore (or overbores in the case of the “leakless” pumps with bearings) may be perpendicular to the mounting surface, but may not be exactly centered on the front of the nose. The cast aluminum fans, on the other hand, are a bit thicker than the original stamped fan, and interferences develop.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! Last edited by JayJay; 11-16-2024 at 08:45 PM. |
#17 |
A lot of folks in the Dallas club run the plastic six blade fans.
#18 |
Many times the aluminum fan will rub slightly on the water pump casting and you have to grind or file a little bit of the water pump casting I ran into this problem on mine and I've read many others that had the same problem.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#19 |
So do you have the old pump or old pump shaft ? Try your fan on that, might be easer than finding a known "good" fan right now
#20 | |
Super Moderator
I just got a Ford fan a couple of hours ago but have yet had time to check it. I am hoping to figure out where exactly the issue is.
