Old 11-12-2024, 05:35 PM   #1
Kube
Super Moderator
Kube's Avatar
Default Replacement 4-blade fan. What say you?
Guys, I'm having an issue getting my aluminum 2-blade fan to seat correctly on a new "leakless" pump from Mike's Affordable.
I have read a bit about "new" pump shafts having incorrectly ground tapers.
I'm thinking of buying one of their 4-blade fans.
What might I be getting myself into here?
Thanks men!
Mike
Old 11-12-2024, 05:43 PM   #2
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Replacement 4-blade fan. What say you?
I am not sure what the problem is but what makes us think a four bladed fan is going to fit better than your two bladed fan if the shaft taper is incorrect?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 11-12-2024, 05:53 PM   #3
Kube
Super Moderator
Kube's Avatar
I am not certain the taper is incorrect. I do not have an authentic pump for comparison.
I have read numerous accounts of the reproduction pump shafts being made incorrectly. Do I have one? I'm simply not sure at this time.
I am attempting to figure out exactly what the issue is.
Old 11-12-2024, 06:01 PM   #4
Benson
There was a time also when the taper on the aluminum fans was wrong and did not fit the shaft taper of correct shafts!
I am sure that some of these bad parts are still out there causing problems.
Old 11-12-2024, 06:14 PM   #5
kurt v
if the fan hub is hitting the snout of the water pump, take a little off the pump to allow the fan to move back more on the shaft.
kurt v is offline   Reply With Quote
Old 11-12-2024, 06:40 PM   #6
Keith True
Keith True's Avatar
Color the tapered part of the shaft with a magic marker.Then hold the impeller in one hand,and slide the fan hub on the other end.Push hard,and spin the fan while holding the impeller still.Pull the fan back off and see what kind of contact you have.
Old 11-12-2024, 06:48 PM   #7
Bob C
Here is a link to some of the problem shafts.https://www.fordgarage.com/pages/waterpumpshafts.htm
I put some valve grinding compound on the shaft and lap it
to the fan.
Old 11-12-2024, 06:51 PM   #8
Kube
Super Moderator
Kube's Avatar
to the fan.
That's the article I'd found earlier that is making me wonder which part (or both) are faulty, the new pump shaft and / or the fan.
I do know for certain the tapers do not match.
Old 11-12-2024, 09:04 PM   #9
Charlie Stephens
I think I would borrow a different fan and try it on the pump. That will tell you where the problem is.
Charlie Stephens
Old 11-12-2024, 11:23 PM   #10
spdway1
spdway1's Avatar
Before you do anything, what did Mike's say when you called them about your problem?
spdway1 is offline   Reply With Quote
Old 11-13-2024, 09:11 AM   #11
Kube
Super Moderator
Kube's Avatar
Charlie Stephens
Charlie, I am currently attempting to locate a Ford fan at this time.
Old 11-13-2024, 09:12 AM   #12
Kube
Super Moderator
Kube's Avatar
They simply could not believe there is a problem with the pump.
Old 11-13-2024, 09:27 AM   #13
51504bat
51504bat's Avatar
Sounds like the guy you spoke with used to work for Bob Drake
Old 11-13-2024, 09:43 AM   #14
Kube
Super Moderator
Kube's Avatar
Ya know, I was a bit surprised as they (Mike's) have been pretty darn good all along.
Old 11-13-2024, 10:07 AM   #15
Tom F OHIO
Tom F OHIO's Avatar
Did you just purchase your new fan. We have been having trouble finding one right now.
Tom F OHIO is offline   Reply With Quote
Old 11-13-2024, 10:21 AM   #16
JayJay
The aluminum 2-blade fans are notorious for not fitting on the water pumps because they rub on the snout of the water pumps. Snyder’s instructions (https://www.snydersantiqueauto.com/c...INUM%20FAN.pdf) talk about this, and Snyder’s should know, they manufacture these things for all the vendors. The solution is to turn or grind down the snout of the water pump housing. I’ve had to do this to four water pump housings in the last two years, and have built a jig to clamp an assembled pump in the lathe to make it quick and easy. I turn the nose to about 1.630" (1-5/8"+) from the nose to where the boss for the front grease fitting comes out.
If you don’t have the pump apart and can't chuck it up in a lathe, the way to do this is to put fresh paint on the snout, then slip the fan onto the shaft and turn it as you very lightly press on it. It will rub and leave a mark on the pump where it hits. File or grind that down, then continue. When you have it turning freely, take just a bit more off to allow for heat expansion. Repaint the snout and you’re ready to go.
The reason this happens, especially with “leakless” pumps, is that the bore (or overbores in the case of the “leakless” pumps with bearings) may be perpendicular to the mounting surface, but may not be exactly centered on the front of the nose. The cast aluminum fans, on the other hand, are a bit thicker than the original stamped fan, and interferences develop.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 11-13-2024, 10:21 AM   #17
Planojc
Planojc's Avatar
A lot of folks in the Dallas club run the plastic six blade fans.
Planojc is offline   Reply With Quote
Old 11-13-2024, 10:22 AM   #18
Fullraceflathead
Fullraceflathead's Avatar
Many times the aluminum fan will rub slightly on the water pump casting and you have to grind or file a little bit of the water pump casting I ran into this problem on mine and I've read many others that had the same problem.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 11-13-2024, 11:06 AM   #19
Phil Brown
Phil Brown's Avatar
So do you have the old pump or old pump shaft ? Try your fan on that, might be easer than finding a known "good" fan right now
Phil Brown is offline   Reply With Quote
Old 11-13-2024, 02:48 PM   #20
Kube
Super Moderator
Kube's Avatar
Originally Posted by JayJay View Post
The aluminum 2-blade fans are notorious for not fitting on the water pumps because they rub on the snout of the water pumps. Snyder’s instructions (https://www.snydersantiqueauto.com/c...INUM%20FAN.pdf) talk about this, and Snyder’s should know, they manufacture these things for all the vendors. The solution is to turn or grind down the snout of the water pump housing. I’ve had to do this to four water pump housings in the last two years, and have built a jig to clamp an assembled pump in the lathe to make it quick and easy. If you don’t have the pump apart and can chuck it up in a lathe, the way to do this is to put fresh paint on the snout, then slip the fan onto the shaft and turn it as you very lightly press on it. It will rub and leave a mark on the pump where it hits. File or grind that down, then continue. When you have it turning freely, take just a bit more off to allow for heat expansion. Repaint the snout and you’re ready to go.
I did place clearance in the fan hub. It (the taper) does not match the taper of the pump shaft.
I just got a Ford fan a couple of hours ago but have yet had time to check it. I am hoping to figure out where exactly the issue is.
