Old 10-21-2024, 09:57 AM   #1
Wick
Wick's Avatar
Default Need more Grease
Well , it's not rusty!
Wick is offline   Reply With Quote
Old 10-21-2024, 10:30 AM   #2
Flathead
Flathead's Avatar
Default Re: Need more Grease
And a covered rear spring.
Flathead is offline   Reply With Quote
Old 10-21-2024, 10:59 AM   #3
Planojc
Planojc's Avatar
More is better, right.
Planojc is offline   Reply With Quote
Old 10-21-2024, 11:26 AM   #4
Mike1291
Mike1291's Avatar
I remember the first time I had to put lube on my A when I did my brakes. Thought that you had to coat all the parts until they were practically dripping with grease. After I had a club member came over and call me a grease monkey when he inspected my job I learned that just a dab'll do ya for most things
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 10-21-2024, 11:58 AM   #5
ModelA29
ModelA29's Avatar
and too much is just enough........
ModelA29 is offline   Reply With Quote
Old 10-21-2024, 07:57 PM   #6
jb-ob
Wick, Post pictures after removing the brake drums.......
jb-ob is offline   Reply With Quote
Old 10-21-2024, 08:12 PM   #7
halpeters
Some is good, more is better, too much is just right....
halpeters is offline   Reply With Quote
Old 10-21-2024, 08:32 PM   #8
Sunny the Model A
Sunny the Model A's Avatar
I see nothing wrong here, I'd much rather see a greasy A than a dry one. Dry=wear=$$$
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
Old 10-22-2024, 12:45 AM   #9
Harrisonmanny87
really needed
Harrisonmanny87 is offline   Reply With Quote
Old 10-22-2024, 08:59 AM   #10
Dino's A
Dino's A's Avatar
Wait...you mean you don't have to grease the brake linings???
1928 Roadster Pickup
1930 Tudor
1943 Ford WWII Jeep
1968 Taco Minibike
Member, Santa Anita Model A's
Arcadia Ca.
Dino's A is offline   Reply With Quote
Old 10-22-2024, 09:54 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
Many moons ago, there was a newcomer to Model A's on his first long distance trip. In preparation for the trip, he took his Model A to friends service station to grease the car. As we left entered onto Staten island during our trip, his newly restored Model A overheated. Upon a roadside investigation it became apparent that he pumped a lot of grease into the rear bearing of the water pump. Enough grease to partially fill the cooling system. His Model A went home on a flatbed.
Bob Bidonde
Old 10-22-2024, 10:59 AM   #12
JayJay
On any new-to-me car I make an early task to pull the front hubs and inspect/regrease the wheel bearings. On my '30 TS I found that the wedges and lower portion of the shoes were just loaded with grease. I guess the person who did that must have been taught to "thoroughly lubricate" like Mike 1291 above. What a freakin' mess! Brake shoes were coated and the drum surface was glazed.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 10-23-2024, 12:51 AM   #13
Synchro909
Synchro909's Avatar
He killed it with kindness.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 10-23-2024, 01:32 AM   #14
German guy
German guy's Avatar
Mine looked that way when I bought it. It takes some practice to learn the right amount to use. I didn't see any peeking out of the front water pump grease point so I kept pumping the gun. When I got home from a drive the entire inside of the engine compartment...and the fenders were covered in blue grease spatters. I learned.
German guy is offline   Reply With Quote
Old 10-23-2024, 05:36 AM   #15
nkaminar
nkaminar's Avatar
An old friend of mine, now dead, used to say "Take it easy, go greasy." But I think he was referring to food.
nkaminar is online now   Reply With Quote
Old 10-23-2024, 10:15 AM   #16
JayJay
I made that mistake. Once.
JayJay
Old 10-23-2024, 04:24 PM   #17
Wick
Wick's Avatar
I have cleaned the mess up, none of the fittings were stopped up when I added a shot of grease.
Afterwards I wipe off any access grease. Like to see clean nipples.
Old 10-23-2024, 04:38 PM   #18
Werner
Werner's Avatar
Guten Abend zusammen.
No machine part has ever broken due to too much lubrication. But many have blocked due to too little lubrication.
I always pump a generous amount of (MoS2) grease into the bearing bushes and wipe off the mush that comes out.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-23-2024, 06:25 PM   #19
Synchro909
Synchro909's Avatar
I was taught to pump in grease till I just begin to see grease coming out again. That is usually old grease but new grease has been added to the TINY amount that is actually in the bearing. There is NO POINT pumping till you have a big gob of grease like that but I can understand how sometimes, it is difficult to see when and where it starts to come out.
What come out like we see the in original pictures is just plain wasted.
Old 10-23-2024, 07:14 PM   #20
frank55a
That's what is known as a floating axel.
frank55a is offline   Reply With Quote
