Old 10-17-2024, 11:03 AM   #1
345winder
Default 40 ford vs 40 merc window regulator question. 2 dr .
anyone know if or has a part number list to know if 40 ford and 40 mercs (2dr coupes) use the same window regulators. they look the same (well looking at pictures on the internet) but trying to find out for sure.
thank you Ford Guru's
345winder is offline   Reply With Quote
Old 10-17-2024, 12:18 PM   #2
Kube
Kube's Avatar
Default Re: 40 ford vs 40 merc window regulator question. 2 dr .
They are NOT the same. I am not certain what the difference(s) may be on the sedan.
On the convertible coupe, the only difference is the length of the arms. Is that the only difference on the sedan? I do not know.
Old 10-17-2024, 12:43 PM   #3
Karl Wescott
Karl Wescott's Avatar
While all coupes had two doors, there is no tudor coupe!. Ford had tudor sedans, business coupes and coupes both standard and deluxe. Mercury only had the sedan coupe. Tudor sedans were in both the Ford and Mercury lineup.
01A- prefix = Ford. 09A- prefix = Mercury. The first two letters of the part number correspond to the number of the body style. Ford coupe regulators and Fordor front door regulators were the same and use the fordor body number.
See Photos:
Clear as used motor oil?
Karl Wescott is offline   Reply With Quote
Old 10-17-2024, 01:17 PM   #4
345winder
lol, yes, I know, it was a data entry error , I initially typed 2dr, but then thought i should clarify coupe and overlooked removing the 2 dr part
Old 10-17-2024, 01:21 PM   #5
345winder
Karl , the first picture you posted, are those both coupes ? looks like it can be fudged to work.
Old 10-17-2024, 01:52 PM   #6
345winder
thank you Kube !
Old 10-17-2024, 01:57 PM   #7
Karl Wescott
The first pix is tudor sedan. If you enlarge you should be able to make out dimensions... they are different.
Old 10-17-2024, 02:16 PM   #8
345winder
I can see the dimensions are slightly different , what I cant see from tiny pic is what the ford regulator is from though.
thank you for all your time !
