Old 09-27-2024, 10:36 PM   #1
oldspert
oldspert's Avatar
Default clutch adjustment
Probably this has been hashed over many times but I will add my two cents. I pulled my engine to check the clutch because I had to nearly push the pedal through the floor to get it to release. Upon checking, I don't think the last person knew how to adjust the fingers because they were not the same height by over nearly 1/8 of an inch and worn unevenly. The disk looks like it is brand new, so at some time in the past a new disk had been installed. The bolts are not graded bolts, if that makes a difference. So a new pressure plate is going in with a new throwout bearing, just in case.
Ed
oldspert is offline   Reply With Quote
