Old 08-10-2024, 05:18 PM   #1
tekatlarge
tekatlarge's Avatar
Default 27 T coupe B pillar broken screws
I have a 27 T coupe, I am restoring. I am working on the cover plate covering the front of the B pillar, that holds the door latch striker. All of the face screws in this cover plate were broken off in the B pillar. I cannot get to the screw because they are broken off inside the cover plate spacers. I am desperate to get these old screws out and a suitable method to replace the screws and nuts that hold them in. they look to be 10/32 screws or something familiar.
Also it looks like there is NO access to the back side of the B pillar at the top, because the window area of the body covers the back of the B pillar, and I am reluctant to pull the body apart there so not even a press-nut can be installed at this point without sticking out into where the window gasket goes to hold the quarter window
1924 Ford Coupe
1927 Ford Coupe
tekatlarge is offline   Reply With Quote
