Old 04-11-2011, 07:23 PM   #1
Chucker
Default Is this a Model A handle?
This handle is stainless clad, handle part appears identical to coupe, tudor handle, the part that fits against the door is flat not curved like a coupe handle, the shaft is 1/2" longer that coupe handle, and no original model a key will go into the lock cylinder. It has a matching pair of keys(not briggs) and the handle and keys appear to be N.O.S. Also the lock cylinder is not removable.
Chucker is offline   Reply With Quote
Old 04-12-2011, 09:00 AM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Is this a Model A handle?
After Market trunk handle?
Farrell In Vancouver is offline   Reply With Quote
Old 04-12-2011, 09:02 AM   #3
Joop
Joop's Avatar
Please put up picture of cylinder
I think it is a Crown handle
Joop is offline   Reply With Quote
Old 04-12-2011, 10:41 AM   #4
FL&WVMIKE
FL&WVMIKE's Avatar
Would this be a 1928-29 locking door handle ? The escutcheon would be flat. I don't know about the length. I don't believe that the lock cylinders are removable in '28-'29 models.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 04-12-2011, 09:50 PM   #5
SteveB31
SteveB31's Avatar
All lock cylinders are removable
SteveB31 is offline   Reply With Quote
Old 04-13-2011, 12:06 PM   #6
Chucker
Tx for responses. A little more info: A crown key will not fit cylinder, by cylinder being nonremovable I meant it is not a late 31 cylinder, I ruled out 28-29 because it is stainless clad. chucker
Old 04-14-2011, 12:00 AM   #7
Marco Tahtaras
Marco Tahtaras's Avatar
Vince is right. Ford produced many replacement handles out of stainless using "current" production materials. When we find a NOS '28-29 outside handle which is nickel plated brass, it was actually made during that period. If it was a service item for a '28-29 vehicle made in late 1930 (or later) it will be stainless clad.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
