#1 |
I just replaced the rear end in my recently purchased 1929 woody.
I did not realize how bad the rear shakles were. |
#2 |
Was your woody wobbly? Be careful, the spring is ready to sprog.
#3 |
From the looks of that spring hangar, I think the entire running gear has not had maintenance in a long long time.
Bob Bidonde |
#4 |
I placed a spring spreader on the spring, yesterday.
I plan on removing it, later today. |
#5 |
A spring spreader should always be used when removing a rear end from a Model A, the rear spring can be lethal. Never remove the rear end with the spring attached. If the shackle is broken the spring can fly in any direction.
https://www.santaanitaas.org/wp-cont...ar-shackle.pdf Tom Endy |
#6 |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#7 |
Here is a great article from Vince Falter. https://www.fordgarage.com/pages/brokenshackles.htm
I had one break exactly as shown in Vince's and Tom's articles. They seem to break right thru thr grease hole. I found it when I was installing my Mitchell O/D. I don't really know how long it was broken. Last edited by Y-Blockhead; 08-04-2024 at 11:30 AM. |
#8 | |
![]() Quote:
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#9 |
Plan on new bushings as well.
#10 |
Look closely at the photos in Post #7 and 8. One hole in the link that bolts to the end of the shackle is elongated from wear. That will put a bending stress on the shackle at the lube hole and cause it to break. It may be that the nuts were not tightened sufficiently.
#11 | |
![]() Quote:
#12 |
This was kinda my thought as well. The shackel has to move relative to the cross bar to get that wear, and to my mind it would only move if it was separated first.
#13 |
Is that a piece of a dog boned shock link? a little corrosion.
Dennis in Kelsey ca |
#14 |
OP's pic #2 shows the dust cap and rubber bushing of an original tube shock link. But you're right, there's a bit of corrosion going on. And a fair bit of caked on dirt/mud.
#15 |
I finally removed the rear spring.
The shackles wore into both axle housings. One of the shackles was actually broken in two. Last edited by Neil Mylar LakewoodCA; 08-06-2024 at 01:03 AM. |
#16 |
No shocks.
#17 |
They look a bit like our "redback" spider webs. If not,we can send you some.
#18 |
The shackle will have just enough length to be able to hinge when the nuts are tight if properly manufactured. The shackle is highly stressed and depends on the nuts to be tight against the plates in order to restrict any flexing of the hinge parts while in service. Looseness will cause failure as much as lack of lube service. Fatigue is another factor that can be exacerbated by looseness of parts. I'm sure that the engineers never expected these parts to last 90+ years in the case of OEM parts. Parts of dubious manufacture and poor manufacturing practices will not take the designed stress of an OEM part. If they don't fit and function right then find another source for the affected part.
