Old 07-30-2024, 07:04 AM   #1
Tom Grz
Default Seat options for 31 pickup
I’m keeping my eyes open for a set of seat springs for a 31 pickup I’m rebuilding as a driver. If I can’t find a used set of springs, I’ll go the plywood/thick foam route, but I do have a couple questions. Are the bottom seat springs the same for all Model A cars and trucks? Are there any bench seat springs from more modern cars or trucks that are known to fit a 31 pickup? TIA!
Tom Grz is offline   Reply With Quote
Old 07-30-2024, 09:11 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Seat options for 31 pickup
I have some unidentified seats that may fit pickups, so if someone puts up the identifying features I’ll check the ones I have.
Old 07-30-2024, 12:52 PM   #3
Herb Concord Ca
There are 2 different 31 seat bottom springs. Use the seat riser as you guide. The seat backs are the same.
Herb Concord Ca is offline   Reply With Quote
Old 07-30-2024, 02:53 PM   #4
ronn
on top of all that- are you average in size? if not you may want to make some alterations.
Old 07-31-2024, 09:16 AM   #5
dan
dan's Avatar
And in this case "average size" means are you of average size for 1931. The average male was around 5' 7" in 1931. If you're of average size in 2024, the seat will be a tight fit. At 6' 1" I don't get into or out of my friend's PU easily.
dan is offline   Reply With Quote
Old 07-31-2024, 10:11 AM   #6
Tom Grz
Ok. I'm 6', 205lbs and not as limber as I used to be. I need to make some repairs to the riser first, then I'll play around with some plywood and cushions to see what I'm dealing with. Thanks!
Old 07-31-2024, 10:28 AM   #7
JayJay
I sold my 30 CCPU because my copilot, after two hip replacements, just could not get in and out easily. Truth be told, it was getting a bit dicey for me too, but I’d never admit that to her. As far as I know it had standard seat springs. So if I had kept it, some changes would have been indicated.
And if you think a pickup is tight, try a phaeton.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 07-31-2024, 11:00 AM   #8
Keith True
Keith True's Avatar
I have a friend that used the third seat from a Caravan.He is tall,so he needs both the cushion and backrest to be thin.He just took both parts off the Caravan framework,and just set them in there.On my 28 open cab,my 30 open cab,and my 30 closed cab I made the backrests with 3/4 plywood and foam.I stripped the upholstery off the springs and just put it over the foam.You will need seat foam,NOT dime store craft foam.
Keith True is offline   Reply With Quote
Old 07-31-2024, 11:24 AM   #9
30Murray
X2 what Keith mentioned. I needed a temporary seat for my coupe and found a clean Caravan seat for $100. It's mounted on a plywood base with hinges so I can flip it up or fold it down, it also has headrests for safety. It works so well that I might just keep it and recover with Model A fabric some day. It looks grey in the photo but is actually black.
30Murray is offline   Reply With Quote
Old 08-02-2024, 10:46 AM   #10
ronn
I just sold a cut down sedan, that was made into a pu.
It had a bus seat in it and it fit pretty well.
6' and Ild guess you;ld want to make a little room on the back and lower cushion. Im the same height, but a bit heavier and had trouble getting in and out of my rpu.
Old 08-03-2024, 12:43 AM   #11
CarlG
CarlG's Avatar
I have a pair of repro CJ5 seats in my '31 CCPU. They work for me, and my wife likes them as well.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-03-2024, 04:35 PM   #12
California Travieso
Send a message via Yahoo to California Travieso
Check out https://www.glideengineering.com/ they make different kinds of seats for Model A’s. You can have them upholstered to fit your own needs.
David Serrano
California Travieso is offline   Reply With Quote
Old 08-04-2024, 08:55 AM   #13
31a
I have a set of wide bed springs out of my 31 pickup m if interested Bob
31a is offline   Reply With Quote
Old 08-07-2024, 07:14 PM   #14
Osage Orange
Osage Orange's Avatar
I'm still a ways from getting to the upholstery, but I've been paying attention because I'm 6'1" and am working on a '29AA. I've crafted my own tilt column, decided to keep the stock seat but will use 3/4" plywood and foam for the back. Four years ago I had cancer (beat it!) and lost 65 pounds that I can't gain back, then in June I caught a virus that led to pneumonia and lost another 15 pounds. Nothing makes it easier to fit in a tight space than less of you. Caution: these examples are not desired weight loss methods. Anyway, now I'll fit without my knee caps in my nostrils.
Osage Orange is offline   Reply With Quote
