Old 07-16-2024, 11:32 AM   #1
john charlton
john charlton's Avatar
Default Thoughts on AA 4speed shift towers .
It looks like I was not the only one not working out how to get the cap off . The hidden cap lock pin grooves were the key . There are many interior cab shots of AA cabs on You tube and some have modifications such as nuts welded to the cap each side . Some with pegs sticking out etc etc . This must have been an early problem as Warner Gear went to the threaded cap and tower and single pin . Much better system but more expensive to manufacture . I got mine apart without any terminal damage and MIG repaired the heavily wallowed out ball slot . In the early shifter the slot is open at the bottom so you have to lay a piece of metal in so you dont weld the reverse rod to the shaft . I did this and prised it out afterwards . The locating pin hole was very worn so I filled it with J B Weld and drilled out . Might not last too long but plan "B" is to drill out and fit suitable cut down drill bit . Nice tight shifter now a big difference .
John in Suffolk County England .
john charlton is offline   Reply With Quote
Old 07-17-2024, 10:48 AM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Thoughts on AA 4speed shift towers .
I know after I redid mine I was amazed at how tight the shifter was before that mine moved literally 8 or 9" in all directions and you couldn't even tell which gear it was in.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
