Old 06-14-2024, 01:42 PM   #1
34fordy
34fordy's Avatar
Default 36 transmission mount question
The plate (B5099a) which goes between the rubber mount and the back of the transmission. The arrow points to the rubber stamping. This was facing the rubber on the mount towards the rear of the car, away from the transmission, opposite what I have shown in the picture. It seems to me that it should be in the direction I have placed it in order for the rear gasket to be effective. Otherwise the protruding rib on the other side would only touch the gasket partially. I doubt that these are original to the vehicle as it is from a 39 transmission installed in 36.
34fordy is offline   Reply With Quote
Old 06-14-2024, 04:51 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 36 transmission mount question
Old 06-14-2024, 05:12 PM   #3
Will Kimble
The side marked “rubber” should face the rubber. The side where the ring pokes out touches the gasket. If you don’t like it you can use one of the more common plates that are flat. In truth it probably doesn’t matter a whole lot.
Will Kimble is offline   Reply With Quote
Old 06-14-2024, 05:29 PM   #4
34fordy
34fordy's Avatar
Will, Thanx. It just does not seem right. My head is probably getting in the way. Do you think it would matter if I installed it the way I have indicated? I do not know the part # of the flat plates.
Old 06-15-2024, 06:20 AM   #5
Terry,OH
Terry,OH's Avatar
Look for a stamping in the metal. Put it on the way it is marked.
Old 06-16-2024, 04:58 AM   #6
DavidG
DavidG's Avatar
B-5099 is the part number of the flat plate.
DavidG is online now   Reply With Quote
Old 06-16-2024, 07:11 AM   #7
34fordy
34fordy's Avatar
Thanks David. I did find that 36 was B 5099 A. I just cannot wrap my head around the protruding rib facing the gasket in only a very small area. The remaining 95% gasket area would have no use whatsoever. Will Kimble mentioned that more common is the flat plate and could be used. If I turn it around it would work like a flat plate as the rib would fit inside the rubber isolation ring. At my age I only want to do this once! LOL Thanx for all the help folks.
Old 06-20-2024, 12:47 PM   #8
34fordy
34fordy's Avatar
I received a new "FLAT" B 5099 from Mac VanPelt this morning. I liked that way it went together and seemed to make a much better application. Thanx Mac VP for the part and your conversation!
