Old 03-25-2024, 12:30 PM   #1
Nick Bernier
Nick Bernier's Avatar
Default Clutch Release Shaft Bushing tool
Hi All,
I'm trying to replace the two clutch release shaft bushings (1940, 40-7508). Third Gen has a tool to drive the old ones out, and new ones in, but they're out of stock. I don't want to booger things up. Anyone have a good tip on how to do it without the magic tool?
Thanks,
Nick
Nick Bernier is offline   Reply With Quote
Old 03-25-2024, 12:41 PM   #2
Tim Ayers
Default Re: Clutch Release Shaft Bushing tool
I been using a generic bushing driver set for years with excellent results. You can get these cheaply from either Amazon or Harbor Freight.
Old 03-25-2024, 12:57 PM   #3
petehoovie
petehoovie's Avatar
Originally Posted by Nick Bernier View Post
Hi All,
Thanks,
Nick
Old 03-25-2024, 04:32 PM   #4
Bored&Stroked
Bored&Stroked's Avatar
You'll probably find that you'll need to ream or hone the IDs of those once they're installed. You can use a basic brake cylinder hone to get the job done.
I made a pilot on my lathe - that picks up the ID as well. These split bushings like to collapse and then the ends will overlap . . . then you start all over again!
Old 03-25-2024, 08:05 PM   #5
Blindhuckster
Blindhuckster's Avatar
I purchase one of these drivers a while back from Third Gen. Here are the dimensions of the driver as well as the bushing. Maybe you can find a driver local that would work. Hope this helps.
Nate
Blindhuckster is offline   Reply With Quote
Old 03-25-2024, 08:53 PM   #6
Blindhuckster
Found this 7/8" driver on this site for $12.00. Might call them and see what the outside diameter of the driver measures.
https://www.hyperracing.com/Torsion-...-SF9k-ARzCYxdI
Hyper Racing 717.220.4470 [email protected]
Old 03-25-2024, 10:21 PM   #7
petehoovie
petehoovie's Avatar
Nate
Old 03-26-2024, 09:37 AM   #8
Nick Bernier
Thanks Nate, and Bored&Stroked. I'll check on the Hyper Racing driver........
Old 03-26-2024, 11:25 AM   #9
19Fordy
19Fordy's Avatar
Check the OD of sockets you have in your tool box. One might clear the bore and fit the OD of the bushing so you can tap it out. If you have access to a lathe you could "turn" a "shouldered" tool with an smaller OD to fit inside the bushing and a larger OD to fit the case. Or, buy a 7/8 bolt, saw off the threaded part and use the shank, square the end and use it as a driver after filing it down to clear the bore.
Old 03-26-2024, 11:48 AM   #10
deuce5wndw
deuce5wndw's Avatar
Last time I did one with a driver I put a hose clamp around the outside to keep it from collapsing the split bushing. worked great.
deuce5wndw is offline   Reply With Quote
Old 03-26-2024, 02:02 PM   #11
Blindhuckster
Mike,
When I check the third gen site today it says he has 15 on hand. Not sure if for some reason that's incorrect. Nate
https://thirdgenauto.com/product/192...g-driver-tool/
Old 03-26-2024, 02:23 PM   #12
Nick Bernier
Wow!!
Thanks Nate. Just yesterday it said "Out of Stock". Just placed my order.
Thanks to all that offered advice.
Nick
Old 03-27-2024, 09:48 AM   #13
Terry,OH
Terry,OH's Avatar
Harbor Freight has bushing driver kit which is inexpensive and fits many bushings. It can be used to install or extract. I like to use threaded rod and nuts to press the bushing drivers, instead of using a hammer
Old 03-27-2024, 04:01 PM   #14
Nick Bernier
Good idea on "pressing"!
THanks,
Nick
Old 04-01-2024, 01:24 PM   #15
Nick Bernier
Good news is the bushing tool arrived. Bad news is I still can't bust them loose. Tried pressing them out with a clamp and tried pounding them out with a hammer. The too actually started spreading one of the bushings out, getting the tool stuck in it for a bit. What to try next?? Heat? I only have a propane torch. Penetrating oil? Should I try to just mangle them with a chisel? Other ideas??
Thanks,
Nick
Old 04-01-2024, 01:39 PM   #16
Mac VP
Mac VP's Avatar
You can use an old slender tipped screwdriver….one that you’ve already pounded on before, and work the tip against the edges of the old bushing. Drive down to force the bushing inward. Generally, then you can finish driving it out with a large brass drift punch. Worse case scenario, you fit a hacksaw blade through the bore and carefully cut into the brass enough to let it be driven out.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 04-01-2024, 04:48 PM   #17
Nick Bernier
Thanks Mac. Mangled it is!!
Nick
Old 04-01-2024, 05:02 PM   #18
Kube
Kube's Avatar
Nick, Mangle away my friend. You aren't trying to save the old bushings.
A little FYI when installing the new bushings: Sand a slight leading-edge bevel on the OD of the bushing so it just barely starts in the hole.
Old 04-01-2024, 07:16 PM   #19
deuce5wndw
deuce5wndw's Avatar
Try the hose clamp around the bushing. It works just like the piston ring compressor as you drive the bushing in. I ruined two before I tried the clamp.
Old 04-01-2024, 07:26 PM   #20
Tim Ayers
It is surprising how they can "grow" in there.
