Old 02-20-2024, 03:03 PM   #1
KeeKeeBoy46
KeeKeeBoy46's Avatar
Red face 40 Ford I-Beam Front Axle
Safe to jack car up at axle midpoint from a strength standpoint to install jack stands ?? Thanks. Kenny C.
KeeKeeBoy46 is offline   Reply With Quote
Old 02-20-2024, 04:12 PM   #2
TJ
TJ's Avatar
Default Re: 40 Ford I-Beam Front Axle
Depends on the size of your jack and you getting it exactly in the center of the axle.
Old 02-20-2024, 04:20 PM   #3
Seth Swoboda
Seth Swoboda's Avatar
I use a floor jack at this point all the time. The front axle is plenty strong.
Seth Swoboda is offline   Reply With Quote
Old 02-20-2024, 05:36 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Where you need to be careful with these I-beam axles and their strength is concerned is when you go to tie-down a vehicle on a trailer, or to tow one or pull it out of a ditch with a rope or chain. When you TIE-on to a front axle, do it at a point adjacent to the perch pin, as that way you're pulling on the well-stabilized wishbone.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 02-20-2024, 05:43 PM   #5
Seth Swoboda
Coop
I would never pull one from the center of the axle. I've replaced a couple axles on projects that were bent from this.
Old 02-20-2024, 06:18 PM   #6
19Fordy
19Fordy's Avatar
On my 40 I only use the center of the front axle when I need to lift the front end only an inch or 2 off the ground. Too much chance of teetering and car falling if jacked too high.
Here's a great thread that offers jacking solutions.
https://www.fordbarn.com/forum/showt...ight=jack+pads
I did not drill any new holes in the frame. Pads are bolted using stock holes.
