Old 01-30-2024, 12:47 PM   #1
JayJay
Default Oil return pipe offset?
The two sealing surfaces on the oil return pipe have an offset because the sealing surface on the valve cover is farther away from the cylinder centerline than the sealing surface on the block. Does anyone know, or have a print that shows, what that offset is? I need to rebraze a leaking tube and would like to build a jig to hold it while I do so.
I'm concerned about the later (longer) oil return pipe. I've seen three numbers for this - A6645, A6647 and A6648.
Thanks a million.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 01-30-2024, 12:57 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Oil return pipe offset?
It can be cleaned, prepped and the joint soldered in place using the engine as the jig.
Old 01-30-2024, 01:07 PM   #3
Randall
Randall's Avatar
Jay here's one I made to check for leaks and a jig to solder ,I show it in video, will measure the off set later this afternoon
https://youtu.be/W9TvsqfyFl8?si=D7_lMIYo7sktTLws
Randall is online now   Reply With Quote
Old 01-30-2024, 01:11 PM   #4
JayJay
Sweet! Thanks a million.
JayJay
Old 01-30-2024, 01:24 PM   #5
Brentwood Bob
Good one Randall. What was the distance off set you used?
Brentwood Bob is offline   Reply With Quote
Old 01-30-2024, 02:06 PM   #6
Randall
Randall's Avatar
5/8”. Thanks
Old 01-30-2024, 03:19 PM   #7
Big hammer
Don’t forget about the distance, bolt hole to bolt hole !
get a bigger hammer tap done
Old 01-30-2024, 04:45 PM   #8
Flathead
Flathead's Avatar
How about using a junk block and side cover for a jig?
Flathead is offline   Reply With Quote
Old 01-30-2024, 05:25 PM   #9
Brentwood Bob
5/8". Thanks.
Old 01-30-2024, 06:12 PM   #10
JayJay
Yeah, could do that if I had a junk block, other than the one that's in the car . But I'll check 5/8" and if it seems close that's what I'll go with.
JayJay
Old 01-31-2024, 11:21 AM   #11
Flathead
Flathead's Avatar
We have plenty of junk blocks here in Maine.
Old 02-01-2024, 02:10 PM   #12
katy
katy's Avatar
Put a straight edge on the side cover opening down to the block opening and measure it. Simples.
Old 02-03-2024, 11:47 AM   #13
JayJay
Katy - that certainly is one way to do it, but I was hoping to get the intended offset so my measurement wasn’t affected by whatever cover gasket is in place. I got sidetracked and have not done this yet, but thanks to all for responding.
JayJay
